sounds to me like the oldschool NISMO r32 turbos.... bush bearing hense the laggyness... good turbos tho.. once they are rebuilt they have the same flow rating as a set of 2860-5s.... only a bit laggyer..
if the compressor cover has .60 a/r on it thats the turbos u have...
hope that helps :(
  • Replies 73
hay buddy
r u willing to seperat the head from the block
ill take it with all bolt ons (plenum etc) if i have to except the turbos and manifolds as they r useless to me as i have a trubo kit already
let me know if ur willing and the price.
i can organise a courier to get it all to me as well
cheers
julz
All depends what you are offering I'd really like to sell complete but pm me your offer and exactly what you require and ill have a bit of a think if the offer is reasonable but if you don't want to pay decent money I wouldn't pm me with an offer
not to sound like a cock but if I'm going to seperate the head from a perfectly good engine it would have to be worthwhile
cheers
yeah mate u actually do sound like a bit of a cock
im after a head un opened with all covers and plenum.
no turbos or anything just the head and plenum
what do u want for it ???
im not gonna f**k around with offers and private message like a school girl if u wanna sell it give me ur price as per forum rules
peace
ahhh.. if only i had the moneys and i was a full license driver...
good luck with the sale mate (if it hasnt been sold).
i'll gladly buy it if its still unsold in a few years ;)
Hey,
Just wondering if you have a spare rubber lining for the drivers side window.
Mine is split, and has a chunk missing, so its quite noisy when driving.
Cheers!
im sorry at the moment i dont have enough time to fix it given i run my own business and so on and im not going to pay a workshop to do it because it would make it way too expensive for you
the headgasket is clearly the problem with the engine and as i previously said it ran faultlessly even with the head gasket problem but on routine checkover before removal it was found
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
