So not to overcomplicate one thread for people who may search these later I thought I should keep this subject separate.
Also while I have my interior stripped I am going to get the windows retinted as I have a damaged rear demister from the last mob that did it (I will name them if I'm allowed to!).
Specifically they somehow managed to cut all but about 2 or 3 of the bars, so I am going to have to get the tinting steam removed first, repair the damage to the demister & then when I am satisfied it's fixed, have the windows retinted.
I also need this done due to scrape marks on the door windows & the drivers door glass having been replaced.
Anyhow from reading I've done, there appears to be 2 places that are the go for re-tint, Autoperfection & Tint a Car.
Tint a car appears to be the only one that sells Bolle tinting from what I have seen so far & they are asking a significant premium for it ($50 more than their next best & at least 100 more than Autoperfections best product).
The big claim to fame with the Bolle tinting was that it is rated to reflect 90% of heat, where as all others are all only about 70%, which is a 2/3rd reduction, so quite significant. Has anyone on here tried the Bolle Tint and able to give a reasonable opinion on it? I am quite curious about this, but not sure if it's worth the extra coin.
Cheers
https://www.sau.com.au/forums/topic/311757-tinting-workshops-bolle-tinting/
we use pretty dark stuff for our surveillance vehicles and have found the old grey stuff was the best (and cheapest).
The new reflective stuff (like Bolle) can distort images and colours when wearing polaroid glasses and is hopeless to film through, not because of how dark it is but due to the material they use.
well all i can say is AutoPerfection is a club sponsor
and has done many many members cars to which i only heard like 2 complaints how it wasn't completed on time due to parcel shelves
This is actually encouraging, I'd rather have to wait around another hour, for them to do the job properly than get a shit job done on time. This will be the cars third lot of tint so I want it to be right!
Hmmm funnily enough I wear polaroids, Bolle's no less! Almost sounds like the tinting itself is polarised, which would help explan such issues. Face 2 polarised surfaces 90 degrees from each other & all you will see absolutely nothing through them.
so where is place to get this tint ay? used on surveillance vehicles.. or pm number contact details..
we got our cars done at tint a car (5 all up and we got a wicked discount saved over $120 per car for the bolle tint) the only issue that i had with the bolle (before i got it done) was that you had 2 choices a blue tinge or green tinge and having a black car both would have looked silly so i ended up getting the midnight one.
The bolle tint doesnt distort images when wearing polarised glasses its crystal clear. if you want a black tint go for something other than bolle.
Blue tint would look alright on a Red car to me. Was more on about the durability & effectiveness of the tint itself.
The only reason I will be going to Tint-A-Car is for this tint, didn't really think much of their customer service when I called them.
The guys at Autoperfection when I called where friendlier & more helpful that way. Only thing is I haven't become a club member yet to get the discount.... Do need to do something about that.
you'll be immediately defected if you use our tint.......some cops tend to go easier on us by producing our licences.
yeah, you'll need to produce your membership card
Steve there's no law against anyone asking for a discount, from any establishment, and they're not obligated to us in the refusal of any such discount either.
However, we probably need to train our sponsors better so as they only give the discounts to members displaying a card.....that responsibility falls back on us, the exec.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
