http://forums.skylinesdownunder.co.nz/show...&threadid=29881
Interesting to see you read the same post Merli. Hehehe
So did you pay $1800 for it Mirkop and now trying to make the big profit or was the $1800 post just full of :bs!:
Cheers
Ken
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-630718
well if you people havnt realised there isnt just one type of OS giken clutch, the are 3 types. and all 3 have differnt power ratings. i can still get anyone on this website a new os giken twin plate for $1800 if they like a power rating of only 300 horses. where as this one has a power raing of over 700. so maybe BIGBLOCKR31COUPE and gtrken should get their facts right befor posting. it would just ake you look a little smarter, if that is possible...
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631157
You're right. There are three types of twin plate OS Giken clutches.
TS2B - Pressed Steel Cover, Twin Plate, 204mm Clutch Plate Diameter.
TS2BD - Pressed Steel Cover, Twin Plate, 204mm Clutch Plate Diameter, Sprung Center.
TS2CD - Pressed Steel Cover, Twin Plate, 215mm Clutch Plate Diameter, Sprung Center.
Japanese Retail Prices are as follows:
TS2B - 143,000 Yen
TS2BD - 148,000 Yen
TS2CD - 158,000 Yen
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631260
TS2B - 143,000 Yen
TS2BD - 148,000 Yen
TS2CD - 158,000 Yen
So what your saying merli is the cheap one that Mirkop is talking about is
143,000 yen which is about $1800 and the one he has for sale is the
158,000 yen one which is about $2025?
Or am I just stupid like Mirkop suggests...??
hehe
Cheers
Ken
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631368
hehe
Cheers
Ken
I'm glad someone was able to draw the obvious conclusion that I was hinting at bigthumb.gif
There ain't $1200 difference between the three different OS Giken twin plates mikrop.
https://www.sau.com.au/forums/topic/31205-os-giken/#findComment-631475
Guest
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
