Mitsubishi Legnum VR4 S-Spec 1996
138k
Luxo spec, with all the goodies!
Rare combination, Manual/Woodgrain/Leather/Trigger Mauve/Moonroof
Bosch 255 Fuel pump
Shadow electronic Boost guage
Bov + factory bov
Blitz Nur Spec Muffler
12" Pioneer Sub
Kenwood Amp
6" Kenwoods + tweeters in front, 6" kenwoods rear
Pioneer Headdeck
Non AYC Rear diff.
13.5k ONO. Open for idea on swaps.
Selling due to cause i want to.
0424505711
Edited by VashR31
https://www.sau.com.au/forums/topic/312067-mitsubishi-legnum-vr4-s-spec/
Would've been more interested if you were in VIC. Wanted a VR4 or Stagea to swap for my HR31.
What are you interested in swapping for?? (obviously a skyline due to advertising here???)
Well actually the car is originally from Melb :thumbsup:
I mean if i drove halfway and your drove halfway, could work out well.
Hey buddy, sorry I should put more detail with the area of swaps.
Musts:
manual, rwd, turbo and worth between 6-9k then cash my way.
Thanks.
out of interest, whats the fuel economy like?
i'm basically looking for something with leather, bit of power, fits a mountain bike, so this fits into the category but i'm a bit uncertain about something as rare as this... is it hard to find parts and servicing?
All comes down to your foot mate! I drove this from melb to syd cruising, got 450km before the empty light comes on (15 L of fuel left) and it's a 65l tank, like 10-11L per 100km.
Parts as in aftermarket there is some, and as for servicing aus has the stuff for it, now if you want to start breaking stuff that's where it becomes a slightly fun to get replacemets, but NZ is massive on VR4 legnums and basically right next door haha.
hey mate. my 33 gts-t is for sale. i may be interested? even more so if u were interested in a swap. i am in tassie but i've got all my cars from the mainland so yeah.. best check my thread on here if your interested for info
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
