I GOT A FEW BITS AND PIECES THAT ARE NO LONGER REQD ALL OFFERS CONSIDERED!!!
LOCATED SOUTHSIDE BRISBANE
RB20DET PARTS:
CAS (CRANK ANGLE SENSOR) semi polished looks good az
TOP HALF OF PLENUM x2
BOTTOM HALF OF PLENUM WITH INTAKE RUNNERS X2 SETS
1 SET OF STANDARD CON RODS
1 RB20DET CRANK IN GOOD CONDITION
5 STANDARD PISTONS IN GOOD NICK 1 COMPRESSED A SELF TAPPED SCREW SO NO GOOD
RB20DET STANDARD OIL PUMP
RB20DET JPIPE SEMI POLISHED WITH STAINLESS BLANK OFF PLUG LOOKS SWEET
INLET AND EXHAUST CAMSHAFTS X 2 SETS GOOD CONDITION ALSO HAVE CAM CAPS AND BOLTS IF NEEDED
RB20DET STANDARD TURBO NO SHAFT PLAY COMES WITH OIL FEED/BANJO BOLTS AND OIL DRAIN AND 8PSI RB25 ACTUATOR HAS THE COMPRESSOR COVER SEMI POLISHED LOOKS VERY TIDY THE EXHAUST HOUSING WAS SUBJECTED TO 3 COATS OF STEALTH BLACK HIGH TEMP PAINT RATED TO 650 DEGREES HAS BEEN RESEALED WITH HIGH QUALITY BLUE RTV SILICONE IS READY TO BOLT AND GO EXCELLENT CONDITION AND APPERANCE.
COMPLETE RB20DET STANDARD HEAD IN GOOD CONDITION STILL VERY SMOOTH AND HAS FACTORY MACHINE MARKS LOW K PERFECT FOR REPLACEMENT
COMPLETE RB20DET BOTTOM END IN GOOD NICK BOLT HEAD ON AND GO SPRAYED STEALTH BLACK HIGH TEMP PAINT CLEANED LOW K AND READY TO ROCK
RB26DETT CRANKSHAFT SUITABLE FOR RB24 BUILD OR 26 REPLACEMENT NO PROBLEMS WITH IT SMOOTH SURFACES ON JOURNALS ETC NEVER RUN A BEARING AT WORST COULD DO WITH A QUICK MICROPOLISH SUITED TO STANDARD SIZE BEARINGS.
RB20DET CAM COVERS 2X TOP COVER 1X BOTTOM COVER
RB20DET VALVE COVERS GOOD CONDITION 2 SETS AVALIABLE
ALL IN GOOD WORKING CONDITION POSTAGE CAN BE ORGANISED JUST ENQUIRE OFFERS AND SWAPS FOR THINGS OF INTEREST ALWAYS CONSIDERED
https://www.sau.com.au/forums/topic/312174-rb20det-parts/
price on cam covers
valve covers
and RB26 crank
please
ok prices for you
valve covers 30
cam covers 40
rb26 crank 250 ono
will do package price on all that if you want too
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5143119
  • 3 weeks later...
just got in complete rb20det turbo engine has 126ks had 100k service done at 95k by nissan japan very good condition sell/swap doesnt have coilpacks ignitor or loom good replacement can come fitted with rb26 injectors also
call text pm or post 0450 728 189
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5175937
  • 5 months later...
Hi there!
Do you have a crankshaft in good condition?
In case you have, would you be interested in shiping one to sweden?
Its impossible to get over here!
Best regards! Markus
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5468782
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
