hey guys
got my 34 4 pots ready to go on an i was just thinking, can i put the stock 2 pots on the rear?
i know of a tracked 31 that has 32 fronts on the rear (i think)
so would i be able to swap my 2 pots to the rear?
anyone tried this before? any success?
thanks
Tom
https://www.sau.com.au/forums/topic/312233-riddle-me-this/
i'm sure you find that the mounting points for the rear will not accommodate a front calliper. you will also probably run into issue's finding a suitable rotor that will fit the offset required for the calliper, and also have the deeper hub for the handbrake shoes. i would also think that by putting a set of fronts on the rear you will probably stuff up the brake bias.
if your after a cheap upgrade for the rear just get a set of R32GTR or R33GTST ones, they are a lot more common that a set of R34GTT rears would be.
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137022
yeah but if you think about it gtst rears are 297 (fronts are 296, if i'm remembering correctly) and the gtst (or gts25t) rears are 2 pots too
i'm upgrading to 4 pot fronts so moving the 2 pots to the rear should help ballence
i'll contact the guy running the front on his rears and find out if he is still retaining the stock handbrake
so for the moment it seems like a no go, i shall delve deeper
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137080
it doesn't quite work like that though. the last thing you want is to reduce the braking force to the fronts by increasing the size of the rears to something that could throw out the front/rear bias percentage (bmc can only dislplace so much fluid)
nothing wrong with just upgrading the fronts and leaving the rears though, as most of braking force is through the front wheels
as said above, just get the rears from a 33 gts-t and save stuffing around
Edited by M I K E
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137115
This is sillyness. If you want to do the rears use r33 gtst. If not as Mike and qwk32 have said just leave the rears as is and upgrade fronts. Buy decent pads, adr braided lines, slotted rotors and upgrade bmc - end of story. Most people do this for the visual aspect and there is no real proof this upgrade is better than a well setup stock set of brakes. Going better like Brembos wouldnt be justified on your rig atm. Watch low pedal position and handbrake issues. Use the search function and read brake threads by other members for more troubleshooting info. If you are after a excellent jap pad and quality brake products I recommend Acre. As I can swear by their products for daily driving.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137171
Never mind delving ...just take your wheels off and have a look - they won't fit.
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137324
33/34 rears share the same caliper/rotor combo if I remember correctly, fronts share the same caliper internally (With longer mounting arms to the hub) but a different disc size. 33 rears can be had for a (relative) pittance, as everyone loves the brembo brake upgrade, and there are always plenty of 33 GTS-T's wrecking. I would go for the 33 rear set-up if you really wanted to double the amount of pistons. I can attest to the rears being a direct bolt up to S1's, I'm sure they would be similarly easy to bolt on to S2's.
I got my front and rear 33 set-up with Calipers/Pads/Rotors (Pads & Rotors near new) off of a rolling part-out 33 GTS-T (defected) for $380. Start searching the classifieds :D
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5138474
yeah i'll just leave it
maybe i'll redrill the rotors and put the old 2 pots on my 31
got my 34 fronts with pads, lines and rotors for $400
i'll see how they go for now then
just gotta find some metalcast paint :D
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5138661
upgrade bmc and get a bmc stopper :D
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5140402
When i fitted the GTT brakes I found the master cylinder worked fine but I see that some people have replaced it - presumably to reduce the pedal travel (although increasing the effort required).
My S1 has a BM50 - what are peope using who have upgraded and from which vehicle are these available (or have you paid the brand new price)??
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5141868
I bought a cusco new at around $150 (Part no: 232 561A). Pedal feel was higher, less spongy and more responsive, but i had a full overhaul to stock brakes so hard to tell (comparing GTT fronts.) Dont know about using second hand stuff here (10-15 years old) but a GTT/GTR uses a BM50 and GTST uses a BM44. Brembos are BM57 and it seems that a 300ZX BMC uses that same bigger cylinder diameter - 26.9mm vs 25.4mm respectively?
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5142824
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
