Hi, i have my 98 Model R34 for sale.
Extras include an Alpine CD MP3 Player connect for direct controll of i-pod/i-phone. Led lights throughout the dash is a nice touch.
Apexi Power FC with hand controller,
Nismo 480cc injectors, GTR fuel pump,
splitfire coilpacks, Nissan Garret Hi flow turbo From GCG - fitted brand new on Jan 22nd 2010 - so it's brand new basically.
GReddy Spec II DSBC(electronic boost controller) Dump pipe-hi flow cat- HKS Hi Power exhaust.
It still has a standard air flow metre! which does restrict power. It makes 235kw atw 15psi. With an overly conservative tune i reckon.
If you were to put a new z32 air flow metre and retune it, it will make upto 300rwkw but a reliable daily street tune may be more like 270-280+ rwkw. Suspension is Nismo coil overs, I upgraded the brakes with RDA front slotted rotors and QFM pads all round, brakes are impressive. Hicas lock bar.
This car was compression tested had new plugs fitted and serviced when the turbo was fitted 5 weeks ago. All cylinders reported between 149 & 153psi which is said to be good. Car is serviced every 5000ks or less. This car is very very clean and straight as you would expect. Handles very well and goes well. Car has no moneys owing and nothing to spend. Never involved in an accident or been to a race track .
It also has 4 near new tyres Kumho Ecsta SPT New in December 80%+ tread. Rego till Sept 22nd 2010
It still has standard clutch wich is worn but does not or has not started to slip.
I have had four Skylines in the last seven+ years. I like them, i look after them. Contact 0410531390
Reason for sale; Home reno's- yay. This will pay for windows blinds and some electrical work. price $17700
Edited by nath799
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/
Price reduced to $ 17500.
The skyline has been in the garage with little use since Christmas, wife drives it to work once a week maybe.
Im selling it so i dont have to borrow more money for renovations. Bills are sitting here awaiting payment.
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/#findComment-5141536
Car still for sale, i have priced it to cheap. Getting silly offers. It is in very good nic. I should readvertise it for 19k ono really.
Now i cant upload more pictures, if you would like pictures of anything i can email them.
It is an excellent low klms car immac paint with good mods.
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/#findComment-5144905
I potentially interested
wollongong is a long way to come to see a car however.
Im sorting my finances out on thursday so ill get back to you then
Do you have receipts for the work done?
Any objections to a mechanical inspection?
Fuel comsumption @ 235rwkw for daily driving?
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/#findComment-5145982
Hi, I can dig out some receipts.
No objections to an inspection, as mentioned clutch is origanal and getting soft plus you can hear thrust bearing in neautral.
My daily drive is a direct 25km run on express way out of hours so its probably lower than most, realistic mixed driving would be 13L/100km.
Where are you from? PM sent. thanks,
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/#findComment-5146822
Guys this is as cheap as you can get. No money needs to be spent. Clutch is soft but it is standard and has lots of life left.
Any genuine interest out there. Someone is gonna get a bargain
Make a genuine offer.
I cant hold the vulchers out much longer.
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/#findComment-5149599
Price is $17100.
Geez how cheap can it get! I wish i was a buyer, i would have this a week ago.
If you want it for less it'll come without power parts. Want it less again? Handling will dissapear then the brakes.
Offers of 15k are too low and the count is around 12 offers. $16 k is starting to become common.
https://www.sau.com.au/forums/topic/312343-r34-gtt-coupe/#findComment-5151829
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
