Hey guys, just wondering of anyone noes of any easy-to-do ways to increase horsepower on your car, i no of a few but if any could help would be greatly appreciated, i spoke to this at a performace shop who told me some but i cant remember but, he said there are plently of site of it on the net, but i cant seem to find any, if any one can help me with this, would be great
thanks
https://www.sau.com.au/forums/topic/31270-more-power/
Being an exhaust fitter that last pic doesn't make me laugh, it makes me cry! WHY!!! WHY!!!
The only free hosrepower that I can think of is a Turbo as it gets its power from spent exhaust gasses.
Here is some mods for N/A engines that might improve power:
Cold air induction, modify and enlarge airbox inlet/outlet and put a bell mouth on the outlet, better flowing airfilter (or pod and cold air box/partition), remove all plastic corrugated intake pipes and make smoother versions out of aluminium tube and smooth rubber bends or aluminium bends and rubber tube (try not to remove vacuum resonance chamber on intake pipe or increase pipe diameter excessively), clean all carbon and oil deposits on throttle body and plenum (or fit larger throttle body or bore out and fit larger vane), Remove any breathers that run from engine to intake and fit oil catch can setup, Next time you change spark plugs choose ones that have a small electrode diameter as this makes it easier for a spark to be produced (reducing the gap slightly also helps in making spark stronger) Ignition Advancing the timing a couple of degrees in some engines might make more power but this is dependant on what octane fuel you use, next time you change engine oil try a fully synthetic high performance friction modified oil (make sure you use the right viscosity of course) this might help reduce friction and drag on engine components, fitting a lower temp thermostat might help drop engine temps for a slightly cooler intake charge, extractors coated in ceramic or wraped in thermal tape, high flow converter and a better flowing exhaust than the factory items will make more power.
Try using some in tank injector cleaner (or get them removed and ultra-sonically cleaned and tested professionaly.)
Run some octane booster/tolulene to raise the octane dont use NOS on a stock engine unless you want a stuffed rings and clutch.
NOTE: This is just a guide, I have no responsability for damage caused to you or your vehicle or the speeding fine that you will get while testing your mods.
MEGA
https://www.sau.com.au/forums/topic/31270-more-power/#findComment-632052
here are some easy ways to increase horsepower:
- straight through mandrel-bent exhaust, big, least amoung of bends as possible
- higher flowing air filter than stock
- remap the ECU or get a chip for your ECU
many cars have characteristics that make gaining horsepower easier (eg if you have a gtr then replacing a tiny hose can unlock a great deal of power). a honda site may be able to provide you with some sort of help with this as here we generally only know RB engines (as they're better)
https://www.sau.com.au/forums/topic/31270-more-power/#findComment-634103
^ What he said :D
https://www.sau.com.au/forums/topic/31270-more-power/#findComment-634119
how do u get a chip for the ecu and how mcuh is it? and how does it work?
go to:
www.unichip.com.au
i hope that link works as i made it up but i'm sure that its their site...
costs about $1000 fitted. it changes the air/fuel ratios and timing that the car uses to create the most efficient combustion in your engine. more efficient = more power. the stock ECU is more aimed at protecting the engine and uses too much fuel, thus if you can slightly reduce the amount of fuel (or 'lean out the mixture') then you can gain an extra 10-20kW or so depending on your engine.
easy, but expensive.
good luck...
Waz.
https://www.sau.com.au/forums/topic/31270-more-power/#findComment-635530
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
