Hey people
I have got the rb25Det I put into my 31 running with everything connected including vct, afm, cooler... And it won't rev above 2400.....
I read it's most likely afm or tps... How can I check these?
It sounds like it's hitting a rev limiter.... Just before boost....
Any ideas?
Thanks
https://www.sau.com.au/forums/topic/312971-rb25-not-revving/
Ok, well its in failsafe which is why it has a 2500ish rpm rev-limit...
Perform self diagnostic (will be a thread in DIY section if you don't know how) & check for codes.
If you have none try wiggling AFM plug & revving car to see if it suddenly revs higher.
If not try same with TPS. Did you do your own wiring conversion?
With no ECU LEDs & no dash light not really... Maybe a light can be hooked up directly?
Like use a pin-out to find which wire is check engine light & maybe it can be wired to a light/LED.
No idea if it would work but only thing I can think of...
hey people,
i have changed the AFM it fixed the limp mode problem straight away....
i have another problem though....
the engine is missing.
i though bad fuel at the start, cos its been sitting in the garage for about 2 months, on very low fuel, so i drove to the petrol station, added octane booster as well as premium, and let it run for a while. still missing on the way home, as soon as i pulled into the garage, it stopped missing, and was running sweet. so jumped back in to take it for a proper test drive, and it started missing straight away.
i have a 044 fuel pump and surge tank, and the pump makes some funny noises like its sucking in air, but surge tank is full... i have never run an 044 before so i am unsure whether noises are standard or pump is fu#ked.
i have changed plugs to NGK BKR5EIX-11
if i fiddle with the CAS and turn it completely anticlockwise, it sounds a tiny bit better....
also, when i back off throttle, the car almost stalls, sometimes does stall.
revs around 900 at idle
just trying to give as much detail as possible....
cheers people
Did you change plugs before or after replacing AFM?
If you done plugs, were in failsafe, then replaced AFM & now have a miss maybe you have just fouled plugs...
Car runs very rich in failsafe & for free worth cleaning & refitting plugs
it misses at idle and under load.....
plugs were changed before AFM was changed....
ill try narrow it down to a certain cylinder tomorrow, and take plugs out to see if fouled.....
car is running very rich at the moment, but probably cos one cylinder not firing?
it really cant be anything else besides coil pack or plugs can it?
cheers
hey again
ok, its cylinder 3 from the front of the block thats not firing.
when i unplug the coil pack, engine keeps missing just the same, if i unplug any of the others, it runs worse....
i swapped the coil pack with number 1, and still number three not working.
spark plug not firing.... so i swapped the plug with a new one, and still no go.....
oh, also, running pfr5g-11 plugs.
any ideas?
Thoroughly check your coilpack loom. If possible remove that section of loom (connects just behind head, maybe half a foot after cylinder 6 coilpack.
Then test the resistance/continuity of all wires from loom connector to coil plug. If 3 is dramatically different from the others I would hazard a guess you have a broken or damaged wire, etc Someone else may know of a more common problem but first thing I would check...
i checked resistance in coil pack wiring, and coild pack wiring is ok. so my problem is between the coil pack plug on engine loom, and the ECU.
as a easier fix, can i piggy back the earth wire from the other coil pack that fires at the same time as cylinder 3? or will this present problems at high revs?
cheers
please guys, i am desperate for help!
i dont know what is going on with my car.....
cylinder 3 is not firing at all. there is continuity in all wires to the coil pack loom from all plugs.
after testing wires, i determined that coil packs turn on via the earth connection in the plug....
the only way i can get cylinder 3 to spark is if i piggy back the earth wire from another coilpack onto the earth wire to cylinder 3 coil pack, but i am thinking none of the cylinders fire together cos it still misses.....
its not a faulty coil pack or spark plug.
it cant be injector related cos spark plug is wet when i pull it out
does any other cylinder fire at the same time as cylinder 3 from the front of the engine?
does anyone know the pin out on the ECU for cylinder 3 coil pack so i can trace continuity to ECU???
i HAVE SEARCHED AND SEARCHED, BUT NO ONE I CAN FIND HAS THIS PROBLEM....
what is going on?
just wanted to finish up this tread for anyone else who has teh same problem in the future....
problem was injector not firing, and as a fail safe, the ECU will not give signal to coil pack to spark if injector is not firing to prevent leaning out...
cheers
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
