  • Replies 57
thanks mate.
its a normal gtr non v-spec and thats the colour from factory, its midnight purple 2.
Ah fair enough.
For some reason I thought only the v-specs/II/nurs or something were the midnights.
Is it a late model? 01/02?
Ok, I fail.
What i'm trying to say is. Awesome ride! :blink:
lol, thats ok mate im a little confused with the whole midnight purple stuff as well, but i think it was midnight purple 3 that was on the later model gtr's.
Hot damn!
Nice 320Km/h Nismo Speedo too!
LOL! It still has the Cassette Tape Deck... How nostalgic!
So when do you receive the car?
thanks mate, cant wait to get my cassette tapes blaring lol.
by the time i get it on the road and ready to go it should be about a month, but thats just a very rough estimate.
Cool!
So obviously Iron Chef will be sorting out compliance / RWC / Rego / Delivery...
Cool!
yep, all i have to do is sit on my arse and pay the bills lol.
i ran the car through nissan fast and its one of the first r34 gtr's to leave the factories. i didnt know they released that colour so close to the gtr's release.
