has anyone else welded a bit around the base just on the one side so the tensioner won't hit? because my thread isn't so great, the tensioner stud is tight in there and doesn't move around, but i dunno if thats enough for me
from personal experience, the just jap rb30de belts are 150 teeth, which if going high compression n/a the teeth meet in the middle before getting the right tention (i ground 0.030" off the block and 0.080" off the head to get 10.5:1)
i know of someone making a carbon fibre rb30de lower cover mould, (who is also making the top and coil pack cover mould for the rb26)
in that case you'd probably have to relocate the tensioner, but it wouldnt be the same spot as the guide, you'd have to figure out exactly where it needs to go.
but for a standard 30det the gates belt and stock locationed tensioners works well, just make the bottom cover on the left side clears the belt by atleast ~10mm. myne cleared on the engine stand but now rubs ever so slightly at a certain rpm and load
I dummy assembled the head block crank cams etc at work, i put a bit of bearing blue on the end of the stud (10mm by 1.5 thread pitch if anyone is looking for the tap / heli-coil set) and yeah it matched what the rb30de guide says. so I heli-coiled it
the gates t306 is the 150 teeth is what i got from just jap
but then i got the gates t291 152 teeth from repco for like $30 (Audi A4 1997-2000 1.8lt 4 cylinder turbo)
also came across this last weekend during my search
SUCCESS
Belt Guide:
Upper Tensioner Relocation Method.
Required Belt Length: 1216 mm
Required Belt Width: 25 mm
Required Tooth Pitch: 8mm
Required Tooth Profile: Trapezoidal (prefered) or Modified Curvilinear
Required Number of Teeth: 152
Compatible Belts:
Gates T291
Goodyear Gatorback 40291
Bosch BT866
Dayco 94680
Dayco 94407
Continental Contitech CT919 (OEM volkswagen belt supplier)
Factory Position - Dual Lower Tensioner Method.
Required Belt Length: 1200 mm
Required Belt Width: 23 to 25 mm
Required Number of Teeth: 150
Compatible Belts:
Gates T306
Goodyear Gatorback 40306
Bosch BT306
Dayco 94777
Continental Contitech CT909 (OEM volkswagen belt supplier)
Gates PowerGrip GT2 1200-8MGT-30, cut down to 25mm from 30mm at factory (still pending)
This is a list of belts that i've compiled through comparing my new T291 belt to the stock SOHC dayco replacement belt for the RB30E. It fit exactly the same around the crank sprocket, so I did some sleuthing and cross referencing, and this is a list of belts that SHOULD be compatible.
When I say SHOULD, I mean that someone mentioned the GT2 to be compatible, and it was not. These belts are in comparison to the level of compatibility shown by the GT2. Even if you've got a GT2 on your DE conversion, it most likely does not fit as well as these ones listed above do.
mmm, I never thought of using a heli-coil I might try that, only reason I'm not using the original location is im doing this build for a friend and he wants it cheap and i got the 152 belt for $19
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
