So, I may be panicing prematurely, but pretty much everyone who has seen my car so far has said "Nah, that'll get written off" - assessor is yet to see it though. As I'm sure we all are on this forum, I am very attached to my particular car and really don't want it to be written off. But if it does, I'm thinking I'm going to take the money and start saving for either a R33 GTR or R34 GTT... maybe something completely different, I don't know.
The thing is, in the mean time I'd want to buy a car that is as cheap as possible but pretty much bullet proof. I don't particularly care about looks, age, ride comfort, anything other than something that keeps going and going and going. The old mid-80s toyota corollas spring to mind. My old Daihatsu Charade was also a bloody amazing car and nippy too for its little 1300cc engine.
We're talking about sub $1500 cars here - I don't want to eat too much into my budget if worst comes to worst and the 33 is a write off.
So, harken back to the days of your P-plates and lets hear about your best old bullet proof bunkie!
https://www.sau.com.au/forums/topic/313237-bullet-proof-bunkies/
If you don't mind looking like a farmer or a tradesman look over the episode of Top Gear trying to kill an old mechanical hilux [talking about zero electronics here, except obvioulsy lights/battery etc].
That and, dare I say it, I've had mates with Skylines, and daily Excels that have overcome some phenominal situations.
Edited by That_timothy
I am also thinking of buying a bunky, but more to save kms when the new engine goes in... Will be following this thread.
Should throw good fuel economy into the mix as well, no point having a car that never stops but costs you as much in petrol as it would to service...
I drove thru the hail storm in my 21yr old A31 Cefiro and the only damage was pin prick dents in the roof which u can only see if u look hard enough, all the windows survived which i was sooo surprised about. Awsome hardy car but i would say MOST reliable.
Doh!...Nana is off the table...hairdresser parts are taking longer than expected.
Dude! I thought you'd dropped off the face of the planet, how the hell are you? Too bad about the nanamobile. I haven't seen you in... well.. must be getting on a year and a half. I'm in Balcatta now incidentally.
Assessor STILL hasn't been so I don't know if I'll be needing a bunky or not. I like the idea of a little shitbox to tool around in though - I really hated taking and parking the line anywhere unusual...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
