I'm having trouble locating some mesh for my new front bar (minimum purchase from one place was 12m by 24m, yes meters :thumbdwn: ). Do you guys have any suggestions? I am after diamond style mesh with the diamond being about 2cm by 1cm.
Thanks in advance.
https://www.sau.com.au/forums/topic/31354-mesh-for-front-bar/
AFAIK, its just sitting down there.
Perhaps give Mark a call.  I will be going in this arvo to have my exh cam dialed in, I can ask for you then if you like.
Great, that would be good mate. I need 1m x 1m I suppose. Let me know.
Just checked with Mark, he said no probs, just go down and see him - although grepin was down there and I noticed the mesh I had was a little smaller than his, so may not be exactly what you are looking for.
1mx1m is a fair bit, are you doing making a front bar our of mesh?:(
Thanks for that. I thought he'd prefer to get rid of larger portions, so smaller is better for sure.
You got good grunt from dyno runs today I hear, are you happier?
I have had a good run in the last day or so, basically tidying up tune and boost leaking from stock BOV. I've gone from 250 to 265 at the same boost (1.2 bar) and heaps more mid range. Car fells totally different, feels like it's ready to kill me!
Sounds good. Its amazing how much difference a small boost leak can rob. I got my boost in about 3-400rpm earlier from blocking the PCV valve, tidied idle up a bit too.
I spent nearly 3 hours dialing in the cams only to find the original setting was close to right. It is amazing, the difference was only minimal going from 0deg to -5deg on the the exhaust.
I am happy considering the setup. The exhaust is definately killing power up top, but that is what you get for a street legal, quiet exhaust. I knew this would be the case, as when I put it on it killed power/spool up when compared to the N1 system I had on previously.
I made 270 at 1.1 bar, 285 at 1.2bar, (not that great when I was making 256 at 1 bar without cams, but the engine has been decompressed) and there after the car starts choking. Final figure was 309. Also, I think I may need to change my intercooler to throttle body pipe - its only 2 1/2 inches diameter, so I am sure a 3" pipe will help it breathe a little better (it was 3" before the trust plenum went on, mick seemed to think it would be worth alot to upgrade). I will get it up on the rollers again when the pipe is sorted, and might just rip off the exhaust to see what happens.
Sounds like its time to get some decent rubber if you havent already, normal street tyres just dont seem to like much over 230-240rwkw.
Group buy for RE540s anbody?:(
Thanks Whats, much happier, Shaun at Boost Worx really put in the effort and care needed and the important thing is the way it drives not the numbers so much.
Steve and co., no more RE540s in Oz left!!! Running them out for the new RE55 which is CRAP, just ask Chris32, only lasted 3000km, whereas Grepin's (and Whats's) RE540s are not quite as grippy but have lasted a long time with a good old caning. Fantastic tyre the 540, pitty.
Bridgestone comming out with harder compound RE55 to address durability issues as there are a number of race categories that are really pissed off with the swapp from 540s to 55s. I think late March for new rubber. Other dissapointing thing is the new RE55s are asymetric.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
