FOR SALE: Make / Model / Year: R31 Skyline Silhouette, 1989
Kilometers: 330,000
Transmission type: 5sp manual
Engine: Rb20DET
Colour: Red over silver
Modifications: See below
Roadworthy Certificate: yes
Accident History: Rear drivers quarter was reversed into and has been repaired
Asking Price: $7500ono
Contact Details: Call James on 0412 621 949, PM or repy to thread.
Other Comments: I’ve owned this car for 4years, before that it belonged to Bullet32s family since new. The 20 conversion was done 4 years ago (out of Bullet32s r32) and has been fully engineered as it sits from wheels up.
Standard exterior except for clear front indicators.
Also comes with Cusco camber tops and a HR31 brake booster
Reluctant sale but I need to buy a tow vehicle for my other 31.
Its getting a machine buff this weekend so I’ll post up pics when its looking schmick!
Modifications;
ENGINE/DRIVELINE:
RB20DET (170,000kms)
3in mandrel bent exhaust from turbo back, High-flow cat, Muffler with 4in tip (Rego quiet)
FMI and BOV
Turbotech boost controller
Battery relocated in boot
Rechipped ECU by CEF11E off SAU
Just Jap short shifter
Xtreme Heavy duty clutch
RB20DET gearbox
Single piece tailshaft
Rebuilt 3.9 LSD (About 4 years ago)
SUSPENSION
Front:
Koni adjustable shocks(good condition but I dont like them, recommend Bilstines)
Super low king springs
Sexy Dave’s Roll Center Adjusters
Whiteline sway bar
Whiteline strut brace
All Nolathaine Bushes
Modified adjustable standard castor rods
Rear:
GTS2 bilstines
Super Low King Spring
Whiteline swaybar
All Nolathane bushes
Noltec adjustable panhard bar
RIMS/BRAKES
Speedy 17x7 +25 Sirrocco’s with 50% federal 595RS tyres
R32 calipers and rotors up front with bendix ultimates
New Standard rotors and bendix ultimates at rear
INTERIOR
Nardi steering wheel
Autometer procomp boost gauge
Pioneer head unit
Pioneer 6in speakers
I can't believe you're selling my car!!
For shame! :)
But seriously - $7,500 for this car is a bargain... I can vouch for how well it has been looked after it's whole life... Sad to see it go. :D
thanks guys, dont really want to sell it but i need to buy a tow car.
Haven't had a chance to buff it yet due to easter and rain, but heres some phone pics.
wheels do have hub caps.
price drop to $6500!
need this gone, will consider swap for a ute or 4wd.
some better pics cause my phone is st1t
  • 1 month later...
  • 1 month later...
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
