Seems like a lot of people are having the problem mentioned in this thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=30976
Basically the cause is most likely a stuffed heater core, which involves pulling your entire dash apart, and its maybe 6-8 hours of work.
So for those that don't just want to do that just yet (but its recommended).. you can actually bypass the heater core altogether. Means you get no heat, and no proper climate control, BUT it also means you don't get leaking coolant, which can mean overheating and then the end of your engine!
For those interested: the heater core just works via coolant (which is heated from the engine) passing through a small radiator, which is in turn stores heat, and warms the car. The coolant then passes back through the firewall, and into the rest of the cooling system.
So, here we go:
1. Leave your car overnight, or at least a good few hours to let everything cool down, and water to settle back into the system.
2. First of all, remove the two hoses that go into the firewall (as shown). One is like the "in" and one the "out" coolant flow.
They are held on via clip type things. Undo the screws using a philips head or even an adjustable wrench. They can be a bitch to get to if not facing an easy direction, so slide them around if you can. A bit of coolant should come out, but when i did it, there wasn't much.
3. Use a piece of hose that will fit in between the two hoses to bridge the two. Luckily i had one that gave a tight fit @ 21mm outer diameter. Hopefully the small diameter hose doesn't cause a noticeable restriction in the cooling system(??). Probably a plastic pipe of correct size would be the most secure way to do it (didn't have one on hand).
4. Tighten up the clamps as tight as possible. Make sure its all secure, and try and angle things so the rubber hose is not too close to the engine.
5. Start her up and give it a test, check for leaks, and any sudden rise in temperature during a test-drive.
I did a short test run, and everything seemed to be normal and running ok.. but keep a razor eye on that temperature guage, and any leak from that area.
I hope this all ok, wrxhoon or the like might be able to have a quick check to see if i've done something no-no. I take no responsibilty for any damage caused by anything in this thread!
https://www.sau.com.au/forums/topic/31403-bypassing-heater-unit-howto/
No need to plug anything.. The heater can just sit their disconnected without any problems. The heater core is just a small radiator really, where water flows in, and then straight out, heating it in the process.
Its possible you can just plug both ends of the hoses at the engine side, but i think keeping the original "flow" in and out of the engine would be best.
  • 7 months later...
Have a look around the firewall they must be there somewhere....i'd imagine they would put the heater in the same spot?!? Try unplugging some hoses and if you pull off the hose and see the yellow heater core plugs then you know u r on the right track. Perhaps have a look under the car - maybe they have mounted them lower if they aren't on the top
Anyone done this on a GTR? Where are the 2 hoses?
yeah was the same place, just more crowded around the area, bypassed it for now, need to source a new heater core, i've been told copper is best, will last forever (well alot longer than a normal one)... then gotta get my dash out to replace it.... not really looking forward to it
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
