having a further read, they explain it plugs into the factory loom. and there is the option of using the standard nissan wheel.
sounds all too good to be true. if you watch the video of it in the 350z looks quite good.
maybe we can do a group buy, id like to see the kit of what comes with it and how hard it is to tap into the factory loom.
Yeah, see that Works Bell kit a bit on Yahoo Auctions.
Can't help but think that a V35 OEM paddle shift would end up cheaper, would bolt straight in (I imagine as they both have the same steering column) and looks/feels damn good too!
And found the pic of this front bar,one of the best bars I've seen in a M35 + this other one (is this color stock?)nice...very nice.
Edited by southern_tango
sounds like we need to do a bit of research mate. i didnt even know that you could get the paddle shift on the v35.
Left = Freeway/Dolphin
Right = Nismo modified with R32 intake ducts. Not sure on the grill... seen it before somewhere, just can't put my finger on where
Yeah, my mates V35 GT8 has the paddles. Damn nice paddles I must say.
Will get a part number if I can get FAST working today :)
it would be good if the gearbox wasnt so friggen slow at shifting. actually it would be REALLY good if it shifted quickly
True, if our trans shifted gears as quickly as the CVT trans "changed gears" (practically immediate), then the paddles would be great.
OR you could just get one of the shift kits fitted (of for guys from the other states, send down your bits, have them updated and shipped back for installation)
your right.
the change speed is a little dismal.
with that change kit and the paddles, would make it pretty good.
on the link at the very top there is a you tube clip of the kit fitted to a 350z, it changes quite well in that.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
