Just thought I'd pass on my positive experience with these guys. Some of you may remember that we had a members' night there early last year and were issued with some VIP cards.
Anyway, I rang to price some wheels, and ended up driving in (from the other side of Ipswich) to speak to Tony. As soon as I mentioned SAU he said "no worries, we'll look after you", and helped me select wheels and tyres. I'm not the most decisive person on the planet so this took a while, but Tony was quite patient. I decided against 18s because of recurrent cost (due to the number of kays I do) on Tony's advice.
Despite not having an appointment, the guys managed to squeeze me in and I drove out with a fresh set of 17x8 ROH 'Drift R' wheels and Falken 235/45ZR17 rubber, for a very competitive price.
I should also mention that they were VERY careful putting the wheels on, using a cross brace instead of air tools and ensuring that the balancing machinery didn't scratch the rims. To top it off, the car drives very nicely, not a single shake and the wheel sits perfectly straight.
The service was fantastic, the staff were friendly, and the price and quality of the product is outstanding. I am one happy customer :(
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/
i needed 4 new tyres on my silvia/onevia as i'd worn the insides of the front and the rears were stuffed from last trip to the mt cotton skid pan. I picked up 4 2nd hand tyres, front were 225 and rear 265 in 18's for the car for $300. The fronts were pirelli p zero's and the rear were bridgestone S 02's. These were 2nd hand but they have heaps of tread left on them. It was great cuz like everyone else i was broke so shortly after xmas. This was thru a guy named michael at all round tyrepower near the albion overpass.
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/#findComment-637351
Bob Jane at Toombul is about the only Bob Jane I have ever been to...and it was only out of necessity. They had great service and I will only use a wheel brace which they were happy to use for me.
The only other places I go for good wheels and even better tyre deal are Quickfit at Newmarket (Scott) or Yerongpilly (Jason). The Yerongpilly store also do Dunlop motorsport so you can get good track tyres for good prices.
If you are in the need for tyres due to better prices I would go and see Jason, just mention my name and he will help you out personally (not in the way some of you may like though...)
Cheers
Neill
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/#findComment-638181
i need to get my wheel alignment done asap. are they any good?
dun take it the wrong way though... i have been down to BobJane at Taringa and they did my wheel alignment 3 times but was still terrible. had to take it down to TyreSelect to get it done properly.
btw, anyone knows TyreSelect new addy?
thks
glenn
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/#findComment-638268
that sounds great guys almost funny.Every tyre shop will balance tyres and use what ever not to scratch your mags.Would you pay for a job if your wheels were scratched...????? Guys this is common service you will find from any reputable tyre shop.The only question to be asked from tyre shops is what is your price.....
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/#findComment-638305
i just got a wheel alignment done by nissan at woollongabba
serious, my car feels brand new
couldnt recommend them highly enough;
make sure they are doing a 4 wheel alignment also!
i picked up some new tyres coz my fronts had worn their insides off
pick up some tritech tyres (never heard of em, but apparently they are pretty good) for 297 each from goodyear at woollongabba
235/40/18's arent cheap :(
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/#findComment-639505
was there today. called at 3 and managed to squeeze in an appt at 4 to get my wheels alignment done. great service & great conversation with Manny or Manuel :confused:
btw, SAU members do get a couple of dollars off the usual price.
paul - Manny/Manuel likes your 31 :rofl: he thinks its crazy.
https://www.sau.com.au/forums/topic/31456-bob-jane-toombul/#findComment-640066
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
