Available:
Update! 26/5/2004
Pictures HERE (click)
These parts are available. If it is not listed here then it has been sold or is not available. Please do not ask for parts that are not listed here or I will give you a ridiculously high price and after you've paid for it, I'll go to a wrecker and buy it really cheap and send it to you.
phorj now has all of the parts, please PM him with enquiries:
http://www.skylinesaustralia.com/forums/pr...do=newpm&u=1333
KYB Gear Climb struts. RS*R springs $300 ono for the front pair
Quarter Panel black (click) $150 each
Steering rack $100
K-frame $75
Power steering pump $40
or rack, K-frame and pump for $150 together
Manual pedals set $150
Clutch master cylinder $30
Steering column with 2 keys $20
Brake Master Cylinder & booster $80
HKS Turbo Timer $40
Alternator $55
Castor Rods $40 each
Front hub $20 each
Front upper control arm $20 each
Front lower control arm with ball joint $75 each
Front 1/4 panels $150 ono each
Windscreen Washer bottle $20
Radiator overflow bottle(missing cap) $20
HVAC Fan Blower: $20
HVAC unit: $100
Dashboard plastic Garnish inc vents and buttons $100
Instrument Cluster Garnish: $30
Hicas sensor unit for standard steering wheel: $10
Indicator Stalk assy: $40
Steering wheel surround (Has small mounting holes where turbo timer used to be): $10
Sold:
Engine RB25DET (inc turbo, intake, exhaust, loom, ECU, airbox, clutch, everything)
Gearbox
Bonnet
Headlights
Bumper & support
Radiator
Radiator support
Castor rod mounts
Front Brakes; 4 spot calipers,Rotors.
Air Conditioning compressor
Air Conditioning condensor
Steering Wheel
Dashboard
Glovebox
Climate Control button assy
Located in east suburbs Melbourne. Will ship interstate at buyers expense.
Direct deposit or cash only.
https://www.sau.com.au/forums/topic/31465-wrecking-r33-gts25t-black-ser1-melb/
  • Replies 90
i will get the dash garnish from around stereo and steering wheel if in good condition + i need the plastic trim from drivers arm rest + plastic from around the gear stick and cig lighter + also need plastic from under dash that cover all of the fuses(under steering wheel)
and i also need the dash pad if in good condition is it possible to get these parts sent anywhere in vic?
SkylineGeoff - I am not certain whether or not the recepient of the engine requires the air con compressor, I will get back to you early next week.
Predator - will answer your Q on Saturday by the time I've pulled it apart that far.
EnricoPalazzo - Sorry dont have rear half of car, should have mentioned in first post.
lindsey34, check PM
--edit--
dave, sorry to you too, I should have mentioned it was only a complete front cut, I'm missing everything from behind the gearstick. No doors unfortunately.
gtrGhosTDoGG11 - no, why do people ask for the control panel? Is there a common problem that the windows dont want to move with it? I've repaired one in the past, it was only dry solder joints. They dont look dry, use a relatively powerful electronics soldering iron (30w so no plumbing irons :() and go over each joint. Should work afterwards....
Bozz thanks for quick reply. The reason I am looking for it is that in the bottom of the pocket there is a screw which holds it down. The plastic has cracked in it so its not being held down.
I guess I could probably fix it now Ithink about it :S
Bozz
as well as the other enquiry I made regarding the A/C comp, I'll be happy to take the Steering wheel off your hands at that price. I'll wait for an answer on the comp before arranging to come and pick it up.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
