  • Replies 90
  • 1 month later...
do you have left inner gaurd liner for the front its the plastic thing on the inside of the gaurds
Passenger side is gone, but I think we still have to drivers side.
Will check and get back to you ASAP.
Do you need to front 1/2 that anchors to the bumper, or the rear half near the door (OR BOTH)?
by left, do you mean Drivers or passenger side? LEFT looking at the car, or left from within the car?
no i need the side that the intercooler is on.. i was after the plastic that resides behind the intercooler the one with the little vents in it... thats cool thanks for the response
When you sold the climate control thing, did u sell the metal bracket that attaches to it (where the headunit and din pocket attach to)?
Are you talking about the metal bracket that mounts the headunit into place?
If so... the 1/2 cut we got didn't come with a stereo or these mounting brackets.
You can get them new from Nissan for about $20-$30 and although they are meant for the Nissan H/U, you can use them to mount aftermarket H/U's without any trouble (Kenwood anyways, you may have to drill a hole or 2 for other brands).
Sorry, but I hope this helps.
Bud if u have both quarter pannels and you're willing to post to qld i'll take em, are they in ok condition?
If you are willing to pay the >$50 for freight to Qld then I will send up to you.
If you're keen I'll call a few feight companies and sus out the best prices.
Drivers side is perfect (beside a bit of glue-tpe stuff from bodykit mouldings). Passenger side has same glue-type stuff and is missing the GT badge.
Let me know if you want me to chase up freight costs.
Sorry for the long delay in reply. If you could organise freight that would be awsome. I'll take both front quater pannels for sure, I wont have the money till next wednesday, though i can give you a deposit if you wish.
Cheers, mat.
  • 1 month later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
