  • Replies 49
not working is nice, tossing up whether to hit the beers again today, I'm kind of hanging out for more alcohol lol!
DAmn you and your beer drinkingness only making me thirsty :ph34r:
Pencil me in for working all weekend.
So sad :devil:
Well Easter has NOT quietened down things in my area, my night was filled with an armed robbery, $80,000 burglary, 2 drink driver's and 300 Sudanese going off at party. Not fun driving down street to be surrounded by angry mob throwing bottles at us in the police van. It's lovely the way society is going.........................down the toilet
