Hi Guys!
After some time, i finally have enough moolah to start building my dream carputer.
Atm i'm just doing the research, gathering up ideas and collecting advices from veteran carputerers? :D
The purchasing, setup and install should be ok, but i need to know how to properly mount the touch screen LCD on the cubby hole on top of the A/C controls.
I've looked around on the net, and find that some G35 drivers have used a conversion kit to mount the lcd. I cannot for the life of me find this for sale anywhere.
I'd like to hear from anyone here who succesfully set up their carputer. Some pictures would be awesome as well especially the LCD part :laugh:
https://www.sau.com.au/forums/topic/314854-carputer-advice-needed/
Hi Guys!
What about an iPhone / Touch (or maybe better still an iPad when released) and ODB2 interface with REVS app or similar;
. Edited by Arcos
Actually, i've already got a double din setup. So playing MP3s. divx and dvds is no problem. But that iPhone obdII interface looks awesome! How much for the device?
I checked this website and it seems that this fella got the lcd mount and frame from a dude called 'god of cpu' over at g35driver forums. But he charges an arm and a leg for it. Over $600 with the lcd!
http://www.bluevalhalla.com/gallery/v/geek/g35carputer/
@ G33K can you post a few pics so we can see your setup?
@ Chris Would you have anything to mount the lcd for sale? Or maybe the touch screen itself?
What's wrong with the 'Reply' function? The typing cursor vanished making it hard to reply or post a new topic? Is it just me?
@ Chris When you said that i could hang my own screen on the stock popups, did you mean actually removing the lcd from my current housing and snap it inside this one? Cause that would be a state of awesomeness! How much bro?
@ Arcos. Interesting links mate. Thanks
I have a spare frame here. $40 and its yours. I have the screen out of already. (it is my programming jig for the lang swaps.)
now bear in mind that if yours is non navi you will need the frame as well.
Thanks for helping out.I'm interested. I've got a non navi v35. All i got is the cubby hole on top of the ac controller. Will this frame fit in it? Not too clear on how this frame actually looks like.Mind showing me a pic of it? Or a link to a website that has one will do :devil:
Cheers
@ Chris
I'd like a photo too for a non-navi edition? Are you suggesting you can supply the popup section of the navi edition minus the screen etc., i.e. just the fascia?
@ dodes47
This was my original post...let me know if you need a hand
http://www.skylinesaustralia.com/forums/Ca...ml&hl=carpc
Video of my OBDII setup, this doesn't show you the GPS/Video/Movie setup but you get the gist - http://tinypic.com/player.php?v=oqaj5f&s=3
<br />@ Chris<br />I'd like a photo too for a non-navi edition? Are you suggesting you can supply the popup section of the navi edition minus the screen etc., i.e. just the fascia?<br /><br />@ dodes47<br />This was my original post...let me know if you need a hand<br /><a href="http://www.skylinesaustralia.com/forums/Carputer-Install-V10-t261099.html&hl=carpc" target="_blank">http://www.skylinesaustralia.com/forums/Ca...ml&hl=carpc</a><br /><br />Video of my OBDII setup, this doesn't show you the GPS/Video/Movie setup but you get the gist - <a href="http://tinypic.com/player.php?v=oqaj5f&s=3" target="_blank">http://tinypic.com/player.php?v=oqaj5f&s=3</a><br />
<br /><br /><br />
@ Arcos, That looks wicked. Kinda beats the purpose of mobile computing a bit though, don't you think?
@G33K Thanks Tim, Nice setup. what is supporting your screen? Have you got some sort of frame or mount behind that lcd? Does it slide back into the cubby hole when not in use?
@Chris, you kinda lost me there mate. What does this navi framework look like? Excuse my ignorance.
@dodes47 Metal bracket in a sort of L shape.
It doesn't slide back in, as the casing wasn't deep enough to have it slide, so instead, i've made it removable. In that, i can take the whole screen out, put in my bag, close the lid and it just looks like a cubby from the outside.
Cheers
Luckily for me, the company i work for has a factory - metal and such
Its a thin, polished bit of steel, which i bent on a table, and then shoved in the "brace/slide slot" at the back of the screen.
Its a bit hard to describe, if you're at the next meet though, im happy to show you.
It all depends on the monitor that you decide to fill your cubby with, or if you go with double din, it vastly changes the setup.
Ok guys, i finally finished the carputer! In the end, i decided to use my eeePC that was lying around, just until i can build a proper one with enclosures and all.
I mounted the eeePC inside the boot and the cables run on the left side of the car. At first i was concerned about air circulation, but found out on max load the temp hovers between 21-23 degrees. Cool
There is a remote power switch under the dash to control the computer's power.
I had to cut a round hole behind the cubby box so the vga cable can get through. Not too happy about this, but it had to be done :)
I've set up the power option to hibernate 1 minute after the "ac" connection is lost so all i have to do is turn off the car and walk away. I push the button to turn it on.
I'm running windows 7 home premium (r7lited) cause the power option and stability is better. With Centrafuse 2.1 as the frontend. iGo 8 is my current gps software.
Took me 2 weekends and 8 cans of redbull to get the job done :P
Here's the parts breakdown and how much it costed me.
* eeePC 901 $275
* 7" touch screen LCD $170
* Gosget USB GPS $40
* Laptop car charger $8
* 5m Cigarette lighter extender $12
* Cigarette lighter 3 way splitter $5
* 2 x 5m USB Cable $15
* 1 x 5m VGA Cable Free
* 1 x 5m RCA Cable $10
Not to forget the hole cutter, glue gun, mounting strips and other stuff i needed to buy to get it done.
Total : $550
Here's some pics
http://i869.photobucket.com/albums/ab251/d...4390_377701.jpg
http://i869.photobucket.com/albums/ab251/d...4390_377700.jpg
http://i869.photobucket.com/albums/ab251/d...4390_377702.jpg
Next project : Setting up OBDII and Voice control.
Tim, i was hoping you can point me to the right OBDII usb interface to use. There's so many out there!
Comments and suggestions are welcome :sick: Thanks guys and sorry for the massive post and pics! Too excited ;D
Good work!!
What did you use to brace the screen up?
Also, how do you power the PC up?
Do you have to go to the boot and push the power each time?
As for the OBDII - get the BlaZt.biz cable, it'll give you everything you need as far as cables are concerned
If you're after something more advanced, i sell an OBDII HUD with TPMS Speed/Rev/Battery Volt/Engine Temp and so on.
Cheers.
Good work!!
Cheers.
Thanks
The screen came with a sliding mount at the back of it. I just reversed it and screwed it in to the cubby hole. There's already a hole on it anyways so i thought what the heck :)
As for the power, i opened up the eeepc and soldered two thin wires to the power button. If the cables get shorted, the computer turns on. So i just extended the wires and connected it to a $2 Jaycar button on the bottom of my dash.
The laptop is powered by a normal car charger with an 8 amp fuse just in case .
I saw that obd2 somewhere on the net. If i recall, they're selling it for $135 usd. Now i don't mind paying that much, but just curious, will this work? http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
If it does why the massive price difference?
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
