Im heading in a different direction, so the RB25 bits are for sale
Engine has received new oil after every track day.
Bare Head, just rebuilt, new seats, valve grind, light port, smoothed bowls $1000 Great for 25/30 swap!! Can provide std cams, includes cam covers and valley cover, just powder coated, includes adjustable cam gears
Tomei Poncams 256 inlet/exhaust 8.5mm lift $700 includes adjustable cam gears
Performance springs to suit above cams and capable of controlling 10mm+ lift $200
6Boost manifold to suit the 3037 turbo $800. Changing from another aftermarket manifold to this, picked up 30hp alone with no changes to boost or timing!!!! Suit turbosmart wastegate. Ceramic coated by Competition Coating
HKS 3037S 56T with 0.74 ex housing. This is rated at 480hp. My engine was making 430rwhp on 19psi on PITS dyno. I will include all the dash fitting and lines for this to bolt up to your 25. This is oil & water feeds and retursn and oil return to sump. You need to tap your block for these to fit. Will also throw in the 3 inch dump from turbo to under the car, suits S13 series car although i imagine it would also fit a R33 but you' need to check it.
Turbo has just been rebuilt by GCG after a gasket failure, and has done barely 50km. Exhaust housing also cermaic coated by Competition Coatings. This thing is brand new again! Grab yourself a bargain, get the real HKS item $2500
Turbosmart Progate 48mm wastegate $400
Aria's forged pistons 86mm plus 20thou and shotpeened and linished rods. $700 Was making 8.5:1 compression
Ryal inlet manifold, individually machined bellmouths, standard tb 5.2 litre, injector holes modified to suit top feeds. $1000
550cc injectors with fuel rail $700 New o rings as of last month!
Dyno graph
Here's the lot, pulled it down for a rebuild, but decided to go in a different direction
Inlet plenum underside, Head has driven 50km since rebuild
Here you can see the scalop to clear the clutch master
Water drain bleed, back of head
Fuel rail
Cam gears
HKS 3037S
Here are the dash lines ( the orange looking things- thats a fire protectant covering) These are real aircraft dash fittings, not the stuff that just looks like it
Can see the Turbosmart Progate here- this has been faultless
Arias with shotpeened and linished rods
IMG_0244_2.jpg'
Enlargened sump with minor baffling $200
Postage at buyer expense, prefer pickup. Items located in workshop in Raceview
  • Replies 49
The head had been ported by Phil Ryal. A god in motorsport for many many years. He was TRD in the 80's and produced all their 2L rally engines.
My engine was assembled to his specs. The head has his special bits all over it.
Put it this way, my current engine guy can't believe my current GTR engine doesn't have oversize exhaust valves, such is the efficiency of the head.
You too can be touched by Phils magic...
If you've skipped over it, the turbo has been rebuilt, new compressor and turbine wheels plus new core it's essentially new. These things punch above their weight. My car was producing 430rwhp on 19pi
Here is the head before i refitted it late last year.
Has had harness check, new seats, pressure tested decked etc etc. Has run only twice since rebuild.
Will supply it with standard cams
thanks i got your PM i cant reply due to post count let me know when you know thanks agian :D
Which manifold the inlet or exhaust?
Haven't heard from the other guy interested, so please provide a postcode and suburb for a quote.
  • 3 weeks later...
  • 3 weeks later...
hey there do u still have the turbo mainfold and can you send me pics and mor info to my e mail plz thank you [email protected]
hey i got your e mail and i answered you... I have not heared from you since that i wat the exhaust manifold
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
