Im heading in a different direction, so the RB25 bits are for sale
Engine has received new oil after every track day.
Bare Head, just rebuilt, new seats, valve grind, light port, smoothed bowls $1000 Great for 25/30 swap!! Can provide std cams, includes cam covers and valley cover, just powder coated, includes adjustable cam gears
Tomei Poncams 256 inlet/exhaust 8.5mm lift $700 includes adjustable cam gears
Performance springs to suit above cams and capable of controlling 10mm+ lift $200
6Boost manifold to suit the 3037 turbo $800. Changing from another aftermarket manifold to this, picked up 30hp alone with no changes to boost or timing!!!! Suit turbosmart wastegate. Ceramic coated by Competition Coating
HKS 3037S 56T with 0.74 ex housing. This is rated at 480hp. My engine was making 430rwhp on 19psi on PITS dyno. I will include all the dash fitting and lines for this to bolt up to your 25. This is oil & water feeds and retursn and oil return to sump. You need to tap your block for these to fit. Will also throw in the 3 inch dump from turbo to under the car, suits S13 series car although i imagine it would also fit a R33 but you' need to check it.
Turbo has just been rebuilt by GCG after a gasket failure, and has done barely 50km. Exhaust housing also cermaic coated by Competition Coatings. This thing is brand new again! Grab yourself a bargain, get the real HKS item $2500
Turbosmart Progate 48mm wastegate $400
Aria's forged pistons 86mm plus 20thou and shotpeened and linished rods. $700 Was making 8.5:1 compression
Ryal inlet manifold, individually machined bellmouths, standard tb 5.2 litre, injector holes modified to suit top feeds. $1000
550cc injectors with fuel rail $700 New o rings as of last month!
Dyno graph
Here's the lot, pulled it down for a rebuild, but decided to go in a different direction
Inlet plenum underside, Head has driven 50km since rebuild
Here you can see the scalop to clear the clutch master
Water drain bleed, back of head
Fuel rail
Cam gears
HKS 3037S
Here are the dash lines ( the orange looking things- thats a fire protectant covering) These are real aircraft dash fittings, not the stuff that just looks like it
Can see the Turbosmart Progate here- this has been faultless
Arias with shotpeened and linished rods
IMG_0244_2.jpg'
Enlargened sump with minor baffling $200
Postage at buyer expense, prefer pickup. Items located in workshop in Raceview
  • Replies 49
The head had been ported by Phil Ryal. A god in motorsport for many many years. He was TRD in the 80's and produced all their 2L rally engines.
My engine was assembled to his specs. The head has his special bits all over it.
Put it this way, my current engine guy can't believe my current GTR engine doesn't have oversize exhaust valves, such is the efficiency of the head.
You too can be touched by Phils magic...
If you've skipped over it, the turbo has been rebuilt, new compressor and turbine wheels plus new core it's essentially new. These things punch above their weight. My car was producing 430rwhp on 19pi
Here is the head before i refitted it late last year.
Has had harness check, new seats, pressure tested decked etc etc. Has run only twice since rebuild.
Will supply it with standard cams
thanks i got your PM i cant reply due to post count let me know when you know thanks agian :D
Which manifold the inlet or exhaust?
Haven't heard from the other guy interested, so please provide a postcode and suburb for a quote.
  • 3 weeks later...
  • 3 weeks later...
hey there do u still have the turbo mainfold and can you send me pics and mor info to my e mail plz thank you [email protected]
hey i got your e mail and i answered you... I have not heared from you since that i wat the exhaust manifold
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
