  • Replies 49
  • 2 months later...
Sorry guys, been out of the country so much this year and i'm back now for at least a few months.
Updating this thread, rods and pistons sold, everything else still available.
Items located in Brisbane.
Bare Head, just rebuilt, new seats, valve grind, light port, hardness checked, smoothed bowls $1000 Great for 25/30 swap!! Can provide std cams, includes cam covers and valley cover, recently powder coated.
Tomei Poncams 256 inlet/exhaust 8.5mm lift $700 includes adjustable cam gears
Performance springs to suit above cams and capable of controlling 10mm+ lift $200
6Boost manifold to suit GT25 flange on the HKS3037 turbo $800. Changing from another aftermarket manifold to this, picked up 30hp alone with no changes to boost or timing!!!! Suit turbosmart wastegate. Ceramic coated by Competition Coating
HKS 3037S 56T with 0.74 ex housing. This is rated at 480hp. My engine was making 430rwhp on 19psi on PITS dyno. I will include all the dash fitting and lines for this to bolt up to your 25. This is oil & water feeds and returns and oil return to sump. You need to tap your block for these to fit. Will also throw in the 3 inch dump from turbo to under the car, suits S13 series car although i imagine it would also fit a R33 but you' need to check it.
Turbo has just been rebuilt by GCG after a gasket failure, and has done barely 50km. Exhaust housing also cermaic coated by Competition Coatings. This thing is brand new again! Grab yourself a bargain, get the real HKS item $2500
Turbosmart Progate 48mm wastegate $400
Ryal inlet manifold, individually machined bellmouths, standard tb 5.2 litre capacity, injector holes modified to suit top feeds. $1000
550cc injectors with fuel rail $700 New o rings as of last month!
UPDATE
RB25 Head just rebuilt, new seats, valve grind, exhaust valves guides light port includes Performance Springs with standard cam$1000 Great for 25/30 swap!!
Tomei Poncams 256 inlet/exhaust 8.5mm lift $700 includes adjustable cam gears SOLD
6Boost manifold with GT25 flange, ceramic coated $800
HKS 3037S 56T with 0.74 ex housing $2500
Turbo, 6boost & wastegate package $3000
Ryal inlet manifold, individually machined bellmouths, 5.2 litre, injector holes modified to suit top-feeds incl fuel rail $800
550cc injectors$600
  • 1 month later...
This stuff needs to go.
I'll now offer the lot for $3500, complete top end package, rebuild head new turbo great manifold, come get yourself a bargin.
[email protected] email me if you still have the manifold
Just re-stating, the head has less than an hour since rebuild, light port new valves stems exhaust guides and performance springs.
6 boost manifold with GT25 flange for HKS turbo
HKS 3037S56T -rated at 480hp. Rebuilt, has done less than 1 hour.
Turbosmart 48mm progate.
Ryall inlet manifold, individual bell-mouths and modded to accept top feed injectors.
Included -all water/oil lines for turbo are real aircraft braided lines and fittings.
$3500 the lot!!
Edited by Simonster
Are the injectors included? What brand are they?
They weren't, but if you want the lot, then i'm prepared to throw them in for another $200.
They are series 5's purchased from Mazfix
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
