Had a issue with my car for the last few months, was chasing boost leaks, looking at blow off valve leaking etc etc....
Never really put much effort into it untill last week when i put the car on the dyno and found the issue after a few runs....
Had 5 runs on the dyno all were showing around 15psi and 330 - 340 rwhp after changing all the cooler hose clamps and some silicons, cleaned out the intercooler etc etc....
Took the air filter off to inspect the turbo to make sure it is still in good condition, decided to do one more run before giving up and going back to the drawing board....
Next run showed 20psi and 405rwhp straight away, a gain in 75 horse power at the rear wheels and 5psi boost!!! because the air filter was not attached! (boost was so much higher that it blew the boost line off for the dyno)
The city in Georgia is sooo dirty that this poor filter got clocked soo bad that it was restricting the GT35r soo much it was choking the hell out of it!
I have cleaned the filter about 3 times in the last 6 months but obviously I was not cleaning it good enough and it was still blocked.
So far I have managed to clean it to give me 20psi of boost but the power is still down so looks like a new filter will need to be imported!
Thought I would share this with everyone, its amazing how much power you can lose from a dirty air filter!
Might pay to dyno your car with the filter removed just to see how much restriction is actually there!
https://www.sau.com.au/forums/topic/315245-car-lost-80hp-and-5psi-boost/
actually its just the dirt and dust on the roads, especially when it rains and the position i had the filter would not have been helping (in the front gaurd)
This country is actually pretty clean, not much smog and polution etc etc. its just the dirt and dust on the roads and everywhere that kills it...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
