hi all, i bought another skyline w00t but im a bit confused about wtf the guy did before me when it comes to styling
its a 1993 skyline so its a series 1, but its got series 2 head lights. what im not sure about is, does fitting series 2 headlights require a new series 2 bonnet/guards/frontbar/grill?
reason im asking is because i wish to change the frontbar over to another style, however im not sure if i should be looking for a frontbar to suit a series 1 or series 2.. i dont remember the bonnet coming down as much too (i used to have another 1993 r33 series 1) so its almost like the front end had been swapped to a series 2
could someone in the know please explain whats involved in changing it from a series 1 to a series 2 and if i should be enquiring for s1 or s2 frontbar/grill?
many thanks in advanced :cool:
https://www.sau.com.au/forums/topic/315530-r335-confused/
Depends how he has gone about fitting it i suppose and if its a genuine bar he fitted properly. Looking at the pic its got the series 2 bonnet, bumper, lights and grill. They are all different to series 1 so but i think the guards would be the same, hope that helps a little.
https://www.sau.com.au/forums/topic/315530-r335-confused/#findComment-5167197
more than likely a sign the car has been in a front end collision. or he really wanted a s2 but didn't want to pay for one.
as for changing front bars, if you are going aftermarket then it shouldn't make much difference as it shouldn't be affected by the lights or bonnet, etc. in fact you could probably even put a stock s1 front bar back on and have it all fit up.
https://www.sau.com.au/forums/topic/315530-r335-confused/#findComment-5167331
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
