Just wanted to doublecheck, im about to wire a Q45 AFM (well 2 actually through an Apexi SAFC II) and since PaulR33s site is down or under construction its hard to find the correct info.
Heres what i've got so far:
Q45 AFM
3 wires marked BDE
B - Signal
D - Ground
E - 12v Power
RB25DET Series 1 AFM plug
4 wires
1 - None
2 - Signal
3 - 12v Ground
4 - Signal ground
5 - 12v Power
This gives:
B -> 2
D -> 3&4
E -> 5
As far as i've read im supposed to unite the Ground (3) and Signal ground (4) and connect it to the one Ground (D) coming out of the Q45 AFM, is this correct?
Though im using the Apexi SAFC II to be able to use 2 AFMs and this thread doesnt cover that it still feels good to know that the basics around one operation before continuing with the next one, which i think/hope i've got covered.
/Dave
try temporary upload here;
http://www.paulr33.com/airflow-meter-wiring.html
the URL will change later so dont bookmark it etc, but until i fix, you can use that page
let me know if you are after a different page
Thanks Paul, appreciate it!
Also if someone could confirm that the RB25 Ground & Signal Ground can be united and connected to Ground on the Q45 AFM it would take some more problems off my mind.
tried this, but my Power-fc isnt set up for Q45 afm's.
so it just would NOT run.
could choose GTR32, gtr33, apexi power intake, rb25, vg30
Im going to have to sell my Q45 afm's, awaiting some Z32 (vg30) afm's now
hi tangles
ive checked the VH41 / Q45 AFM ramp in the RB25DET powerfc and its not that much different to the Z32
the Q45 has a touch higher airflow values in the higher range, sub 3v but below that it's pretty close
i would expect your car to idle with Q45 AFM's even if you can't select them, if anything it should be a bit grumpy and maybe blow a bit of smoke at the worst case. with my R33 GTST and stock AFM (s2 AFM) im able to choose VH41 / Q45 from my AFM menu while the engine is runing and it keeps idling, the idle drops a note but it continues to run correctly (i would expect it to).
so i expect that something else is wrong, mangled wiring, incorect wiring, dead AFM etc
you could check them both out at ETC, SENSOR SW CHECK and look at AF-1 and AF-2
they should be pretty close at key ON (but not start) and shouldnt have a black highlighted background on the sensor name
if you have access to datalogit you can edit the AFM RAMP (not visible on hand controller) to make any of the AFMs on your menu match the Q45 ramp set by apexi (takes about 2 minutes). but it is a shame they didnt program the GTR RB26 tune with Q45 on the stock menu. there is bugger all difference between BNR32/BCNR33 so why bother putting them as seperate options on the AFM menu
Connected everything up and so far so good, though i still have to mount the gearbox and startermotor before trying an actual start up.
Clicked around in the Apexi SAFC II menus and found where to set what AFM im using but they're simply a figure01, 02 etc etc but i dont actually know what to try out when im running the Q45s or if this is actually for the output into the ECU which in that case would be 01 for a stock R33 GTST sensor cable.
Also dont know if i have to actually have to set that im using 2 inputs or if it gets registered as soon as it gets a value from the second AFM cable.
Monitoring the AFMs in the SAFC they gave ~0.248v and ~0.250v when key is in 'ON' position.
Found where to set the output to AVG (average) so that part is cleared.
Hi Paul,
I'm running an R33 series 2 RB25det with a VG30 AFM on PFC, I've got my hands on a VH41 unit and was wondering is the wiring the same for the VG30 and VH41 AFM's or do I need to re-wire to match? I cant seem to get your earlier posted wiring diagram.
Cheers! :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
