yep, already too many of them involved in accidents.. and then being classified as "high performance cars" and then the cops are after them..
i mean.. sure you can drive like there is no tomorrow.. but think about us :D... i bet when i get the money to have a good car that -might- be "hi performance" they would be outlawed..
https://www.sau.com.au/forums/topic/31595--/#findComment-638393
yep i was been a fool b4
so i learn it the hard way
i mean...its sad to see others to learn the hard way as well...
i call him moron coz he didnt estimate the power of the car...and try to be a hero maybe...what u get out of it is pain and lost....not worth it...
if u wanna keep it...treasure it...
https://www.sau.com.au/forums/topic/31595--/#findComment-639571
ST.KILDA ROAD as everyone knows is very busy and considering not one of you saw the actual accident i consider u take time out and fink dat maybe it wasnt his fault!!! i dont know anyone that would drive an r34 recklessly, unless off coarse der loaded in which case i belive dey can drive it how evah dey want, crash it wen evah dey want, as long as der not endangering anyone else or their own lives!!! but any way lets not all jump to conclusion and just hope the driver n passangers of the car are ok da car will get fixed im sure....... :goddam: ohhh and by the way if it was there fault n if they were driving recklessly then vikii ur right their MORONS :rofl:
https://www.sau.com.au/forums/topic/31595--/#findComment-639969
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
