dont get me started on just jap birds, if they don't like the way you look, the price goes up 10%.
Also i bought split fires from them, a whole box, through the window of the box it looked like there were six coils in there, 2 minutes after i left i stopped at a maccas around the corner from them and decided to open it up and there were only 5, and the 5 were used. after 30 minutes one of the guys there admitts he didnt check the box and regurlarly they get returns or sell individual coils where there may only be 5 coils in a box instead of six.
I boycot them ever since, imagine if you ordered it online, there goes $600.
I send for japan now anyway, everything is cheaper and never had a prob
https://www.sau.com.au/forums/topic/316303-sti-22b/page/2/#findComment-5177854
ahahaha, ask munkyboy about the problems he has had with them
https://www.sau.com.au/forums/topic/316303-sti-22b/page/2/#findComment-5181504
potential new car Kujotk?
Funny you should say that Nick, I actually picked up a new one yesterday and now my other cars are wasteing away in the driveway being destroyed by the elements.
PM me and i'll send you the link with some pics of it, lets just say comprehensive insurance is $6k/year and shannons/dawes ect... wouldnt touch me because i'm under 30 years old.
Edward lee has the worst rep for imports on Parramatta road (and thats pretty fkn bad).
https://www.sau.com.au/forums/topic/316303-sti-22b/page/2/#findComment-5182257
From reliable sources around 4-6 were officially bought in the country by Subaru Australia. Subaru kept one and put the others for sale. Though I have personally seen 4+ private imported 22B's. Yes you are correct. 400 were made along with 3 prototypes numbered "000". The prototypes were given to David Lapworth, Colin McRae and Nicky Grist. From memory they made a extra 50 "Type UK" 22B which were only sold in Great Britain.
Where abouts do you live? You are lucky to spot a 22B is Australia. I personally have only seen 2 in the flesh (Both being at dealerships). I know of an owner who lives up near Woy Woy, Sydney.
Its hard to tell if its a Japanese or Australia delievered because 400 were made from 1998-1999. All of the 400 cars were sold in 48 Hours.You also mention it sounded better, potentially beacause the 22B had a unique 2.2L boxer engine rather than the usual 2.0L. It was the first Subaru to have a Intercooler water-spray button, adjustable rear wing and a changable Diff. Doesnt sound like much now but back in the late 90's these were very well above the current technology.
The 22B didn't have a radio, airbag or even ABS (IC waterspray taking up the space where the ABS was). Though it did have Blistein supension, STi struts, BBS Elektra wheels and a WRC-Spec wide body kit.
I don't think they were that high - I think it was only 3-4 Aust delivered ones. Most of the ones that are here are private imports
https://www.sau.com.au/forums/topic/316303-sti-22b/page/2/#findComment-5200644
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
