Hold Switch On The Automatic Gearbox
140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
By Nightmare_mistress_R33 · Posted
I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger? -
If you are getting that sort of fuel usage, you might as well be back in the stagea
Looks good mate, those stainless lines must be a bastard to do neatly. Better get it to a track again sometime soon, I'm doing to Wakie day next Wednesday to see if the v37 likes cool weather better than hot weather....
If you've got spark, and you've got fuel, it needs once last thing to go vroom... Have you compression checked the motor?
