Wondering if someone might be able to point me in the direction of some stock R33 or R34 GTR rims for a reasonable price. I want a second set of rims for 'play time'. I went out last night and took a good 20% off my expensive tyres. So I need to buy some cheap rubber for drift practice.
Surely some1 has seen a set just sitting around an imported or something. (VIC preferable)
Or can any1 recommend an alternative that is cheap?
https://www.sau.com.au/forums/topic/31676-sideways-action/
Stock R33 GTR rims are about $2000 - $2500 although occasionally you see a set for $1800 on here.
Stock R34 GTR rims start at $3000 and go up.
If you want some rims that will fit then stick some R33 GTST rims on (16"). There are always 3 or 4 sets going in the 4sale forums...
https://www.sau.com.au/forums/topic/31676-sideways-action/#findComment-641439
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
