  • Replies 194
Hey dluded good to see that u decided to bring the prelude along...did i convince u?????:)
It will be good to have some more "normal" cars:D to cruz with as im sure we will be on the recieving end of some kind of comments......all i can say is bring on the windy, twisty roads and i'll show u what a 1990 GSR, drop on the deck is made of!!!!!:)
As for the straights well pfft..............:shake: its all about the cornors baby!
CYAS THERE.....
I'll be a Terry Hills starter
CIAO
Hey guys and gals,
Very bad news... I was informed last night by a friend that lives at windsor that the putty rd is closed due to fires. NOT HAPPY JAN.
Fortunately for us, Richmond windsor just happens to be the meeting place of 3 great roads. So I have devised an alternative cruise if the putty is still closed come sunday.
Meet as planned at windsor macca's.
Head up the Bells line of road to Lithgow.
Across past lake lyle to Taranar pub for lunch.
Head back down through oberon area to jenolan caves road and out to the GWH,
Travel along this until we get to Katoomba and cruise along cliff drive.
Back on the GWH and to the Grand view hotel for a refereshment and then off home... should see us arrive back at roughly the same time or perhaps a little earlier.
Shit I hope that the putty is open though... heaps less traffic, lot nicer road. HEAPS easier to keep everyone from getting lost.
Am working on some alternate maps as I type this.
We will make a descision on Sunday morning.
My mobile if anyone needs to contact me is 0414 940 938.
Cheers,
Dan.
Just checking up on the net for bushfire updates and found the following at http://www.bushfire.nsw.gov.au/media/Mores.asp?Id=395
"CHAPMAN’S (BOGGY SWAMP) – SINGLETON
This fire has also taken significant runs today. It is now across the Putty Road near the Half Way house, into area burnt in November 2001. Crews are currently deployed protecting properties in the Weeney creek area. The western area of the fire will burn into an old fire of November 2001. Aerial resources have been deployed to assist in management of the fire."
It doesn't say anything about the road being open or closed, but hopefully the fire will have burnt out or at least be controlled by Sunday.
Come on you bushies, I have every confidence in your ability to control this fire!
Fingers crossed.
Great News,
The Putty is back open... was reopened yesterday at about lunchtime and is still open now.
Lets all hope that it stays open now untill we go.
See you all at macca's for bacon and egg mcmuffs tomorrow.
Cheers,
Dan.
Silver,
There is NOT going to be a meet at M4 macca's.
Only macca's at windsor and Homebush 6c... and the Terry Hills Burger king @ 7am, no M4 meet.
Hope this isn't too late.
Oh shit I just remembered. There is a big push bike ride between sydney and wollongong, may cause traffic problems.
Call me on 0414 940 938 if you have any problems.
Cheers,
Dan.
Me and My Old Man will be there- Have a Jerry can in the boot and a bottle of Nulon Pro Strength in the Glove box .... Oh and a few other goodies !!! he he he he
It's gonna be HOT 2morrow - I advise all to bring H20 with them !!
B
Dan, I just had a last minute roster change so there's now a chance (about 1%) that I'll be there. I'll call if I'm coming.:uhh:
Silver and Bonkers, if I bring the X-Trail we'll have the mall-wheel-drive segment sewn up! :)
7am at Terry Hills B'King - you better be there!
... if I bring the X-Trail ...
which, of course, you wont! :) :uh-huh:
Originally posted by PranK
Maj - guess its me and you! :) (almost!)
EVERYONE - make sure you have petrol PRIOR to meeting tomorrow.
PranK,,,,Tanks Full and I'll be waiting for you at 6c buddy,,,,,,,,,Don't be late.....I can't wait,,,can we go NOW.....
This road is an OLD time favorite,,,takes me back to my Motorbike days,,,shit thats almost 20 years ago....
Neil.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
