hey wats up ppl...is there something wrong with my ECU settings, like HICAs maybe? cos every time the road is dumb/wet my R33 GTS would go side ways from the lights in straight line mind u i'm not evening puting my foot down and if i put the foot wen its doing 60kmp it would not stay straight my qestion is.....WHY WHY WHY WHY WHY WHY WHY WHY??????
Edited by Mr366
https://www.sau.com.au/forums/topic/317925-skits/
I am still wondering what the topic and sub topic mean????
anyway....start with taking the car for a suspension check and wheel alignment. You might have either something lose or heaps of toe out. Maybe chuck $14 at pedders and see what they come up with.
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5197336
How about "skits" = "skids"?
NFI what "swining" is about.
WTF has happened to the english language?
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5197914
HICAS starts kicking in above 60kph. If your hicas steering sensor is mis-aligned to the steering rack, you'll find the steering wheel will slowly 'roll over' above 60kph (and will snap straight at 110kph when HICAS turns off).
I could imagine, depending on how badly it was mis-aligned that it could get a bit dangerous in the wet. Certainly the 'snapping straight' at 110kph as it turns off can be dangerous even in the dry.
If you think this sounds consistent with what you're seeing, you can take the car to Nissan to get them to use CONSULT to check the HICAS - they can check the steering angle sensors vs the steering rack and should be able to re-align it. Alternatively, you could just use a HICAS lock bar - though in some states you may run into problems with this without it being an engineered modification.
https://www.sau.com.au/forums/topic/317925-skits/#findComment-5199113
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
