Hey Guys,
Basically im looking to buy a cat back exhaust system for my R32 gtst. Now the guy i bought the car from (dealer) has said that they can make one custom for the car basically for half the price of buying one from say RHD japan. It wont be in stainless steel but he seems to think that exhausts dont rust anymore due to better fuel etc so no need to SS. Now the exhaust that i was looking at buying is a HKS Hi Power Silent.
Oh and the guy has been helpful all the way thru buying and has been looking after me so i dont think he's trying to pull my leg or screw me over.
So my question is this. Is a HKS H-P-S going to be that much better in terms of performance and sound than a custom built one? Pro's cons?
Cheers
BG
https://www.sau.com.au/forums/topic/318309-r32-gts-t/
I gaurantee his "half the price" will work out to be the same, if not more than a local off the shelf catback from some one like X-Force or similar. What price did he say?
There are plenty of options available if cost is a concern rather than going to one of the most expensive makers, HKS.
https://www.sau.com.au/forums/topic/318309-r32-gts-t/#findComment-5201900
As above... Just get something local (SAU Traders are a good start).
Or just get a Jap one 2nd hand from the For Sale area, always exhausts of various types up for sale and well... an exhaust is just metal :D
Long as it's not majorly dinged and the mufflers are intact that's about all you need to worry about
https://www.sau.com.au/forums/topic/318309-r32-gts-t/#findComment-5202076
the hks hipower are beautiful mate, awesome sound and not too loud, looks great under the car. they are also mild steel tho, fyi
im in agreeance with the above comments, something local will be good. Xforce, despite being made in china and almost noname, are excellent. Ive personally seen alot of cars with prefab xforce systems that fit, and sound great.
a custom job can turn out great if you go to the right place, but it will end up costing you more than an xforce or JJR (if ur not worried bout how loud it is JJR arent too bad)
remember to use a good quality cat tho, GL
https://www.sau.com.au/forums/topic/318309-r32-gts-t/#findComment-5202098
Ok so custom can be good if i make sure its done right. If i was to go the custom what should i ask for? Like a high flow cat etc etc. I dont really want it to be too loud im more of a quiet growl kinda guy haha. Is there anything i should specify in the build to maximise performance or noise/note?
Looks like ill have to have a look around at some local SAU dealers as well.
Cheers guys
BG
https://www.sau.com.au/forums/topic/318309-r32-gts-t/#findComment-5204296
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
