Hey guys i have a R33 that has the following mods
Trust catback
3" dump pipe
de cat
blitz pod
boost tee 9psi
walbro fuel pump
Last time its returned 255hp 188KW at 9psi (dont want to go any higher and goes into R&R after10psi)
i have a Power FC, plazaman plenum, front mount and tomei FPR to go on next but turbo choice
Is the 3076R to small with the .63 rear for the 25? and would the internal gate or external gate be better i would love to run external gate but is iit worth the extra money
i want fast response and good midrage to redline pull i want to use the car for daily driving, drift and every now and agian drag and curcuit. power comes second to response and relaiblilty for me i wont be pushing it to the extreme but i want headroom.
Yes i have upgraded all the suspension and braking in preperation for more power :/
  • Replies 56
IMO the .63 is to small for the GT3076 (given its a 300rwkw(+) turbo).
If you want super response and a .63, then a GT3071 fits into the equation there much better.
It should make around 250rwkw give/take and should still hold nicely to redline. It won't be anywhere near the top end the GT3076 will have (in a .82)... but all comes down to what you want.
More response or more top end. Something always has to give.
External gate is not required either way.
Are you using factory exhaust manifold or not?
3076 .82 is still boring and small
go bigger if u want something that will scare u a little.. maybe 3582r .82 mmm
way to much lag for a 25. I wouldnt go that setup unless it was a 3litre. Even still i think the gt3076r 0.82 in a 3litre would be my first choice.
Id go for an external gate. I regret not getting one on my gt3076r
might be a bit laggy but once it comes on its fun :D
3076r arent exactly the most responsive turbo either. i dont see 20psi until 4100rpm
How would it scare him making 300rwkw?
All it's going to do is be overtly laggy for the power and a silly suggestion really...
If there was intent to make 370-380rwkw then fine, GT35...
Fact is he isn't so getting a turbo that's oversized, for upto 300rwkw, and will make it overall slower - totally against what the OP wants anyway.
cause ive got near 300rwkw with 3076 .82 and its boring only going off proof :D been in 350kw gt3582 and let me say alot more fun and alot f**king faster, but hey thats me
lol already bored with the 3076? should've kept your old turbo and get a set of cam gears :D . Well. I'm making 321rwkws out of it (hypergear build 3582 in .82 housing) at moment. I'm seeing full boost on 4300RPM, not much on 1st and low 2nd. but 4000rpm+ on 2nd, 3rd, 4th it flys. Need to get more traction.
and you need some thing bigger then .63 to work with a GT3076 core. But should be good enough for about 270rwkws mark if you can hold boost.
Edited by kwickr33
He has a factory motor mate... come on... use some logic.
Of course a 350rwkw car is going to be more "fun" above 100km/h than a 300rwkw car. On the street however you've gotta argue what's going to actually be faster.
Mine with 280rwkw is virtually perfect, when it had 370rwkw it was just impossible.
Running 350rwkw through a factory motor that is going to see some circuit/drift... It won't last very long at all.
With a 3071 it will cover EVERY single base thing OP wants and still be in the realm of reliability.
yeah i understand nismoid.. just dont want him bolting on a so called balanced turbo that isnt going 2 give him that "wow" factor lol not saying 3076 is completey boring but it just doesnt cut it i dont think even for 300kw range hey.. maybe im fussy?
sell it to me then...pm me if you REALLY want to get away from it.
must be internally gated though
Boring??? Small???
The 3076.82 i had on my car produced 370rwkw and had full boost by 3900rpm. Smashed anything on the rd and IMO a more of a handful than the GT3582.82 i have now.
Light switch power from low RPM compared to the gradual push of power from the 35R.
They are not as laggy as you think, a mate is running one on a stroked 2.4ltr 4cc vr4
Boring??? Small???
370rwkws with 3076 .82 On stock RB25det with 98 fuel? what boost?
Edited by kwickr33
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
