I'm trying to get the cams out of my RB25DET (R33 skyline) and can't seem to get the big 19mm bolt undone on the inlet (VVT) cam gear. Am i supposed to twist it the normal way to undo it (clockwise) or the opposite way (anti clockwise)?
Am i going about it the right way? or is there some other way of getting it off?
Thanks
Andrew
dont twist it too far otherwise there maybe contact of valves with pistons as cam gear will turn coz some are overly tight. My best advice is to give it a quick short jolt with a rubber mallet on the spanner. Continue with this afew times and it should come loose. Can be a stressful thing. goodluck
yeah i did the rubber mallet thing but it didn't help. I need to know which way to twist it though. I'm not sure if i should be going anti-clockwise like you normally would to undo something, but normally on rotating parts you undo it the same way it rotates.
Thanks for the tip though with the moving of the cam. I'll make sure it doesn't turn too far (it hasn't yet).
this is gonna sound dodgy but when its needed it is handy. U can also get a big screw driver and poke it through one of the holes in the camgear itself and sort of jam it from turning. Then proceed with the spanner and mallet trick. Best results would be if u had someone to hold the screwdriver tight so u could concerntrate on the cam gear bolt. Generally i would imagin u would undo it from anti-clockwise direction but a quick call to a performance shop will mend the query
sweet as... i'll give it a go. So looking at it from the front of the engine you turn the nut anti-clockwise. I would have thought to undo it you turn it the same way as the cam turns (which i assume is a clockwise engine rotation).
Thanks
Andrew
hehe... you were right. I got it off.
It's funny, i would have thought that to undo the bolt you would do it the same way as the rotating part, otherwise it can undo itself while rotating. As the cam turns clockwise, that's the way i would assume to undo the bolt. I'm pretty sure that you undo the crank bolt clockwise. Oh well... it's off now, and i think my pistons a buggered :cheers:
Gotta check the head tomorrow for burnt valves... i think too much boost and not enough tuning was the cause!
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
