It is quiet, but there has been some well off topic chit chat lately, some multiple (same) posts, and the parts substitute sticky hasnt been updated in a while. I think the Cefiro Parts Classifieds is moderated by someone else again ?
If you want it'd be sweet, it'd be stuff all work for whoever is designated.
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5209662
I'd be up for it, but figured it was out of the picture with a warning on my name.
But then again, my name means "Victory of the People" in Greek, so I should automatically be entitled to powerfull rights.
Shan, didnt realise you were a mod on here...thought there was only the guy who used to own [CEFFY].
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5209695
Well I'm an admin, so I can mod everywhere, but this is my little pet section that I started up, so I try to keep an eye on it :(
I got no probs with you or toffy as a mod, I'll have to run it past the other admins though before we give you the necessary permissions.
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5209698
Well I'm an admin, so I can mod everywhere, but this is my little pet section that I started up, so I try to keep an eye on it :D
i'm easy , nic can do it if he wants or i'll do it no worries :(
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5209756
Nikolaos aye
you greek brackground?
sorry for off topic.
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5209821
I reckon both nic and toffy should have a go. They seem to be on here a lot. Like Nic said its not much of a job to look after this section and both toffy and nic are on here enough to be given that responsibility. Ive been thinking the same thing about this sub forum for a while.
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5209845
Appears my smear campaign on that asshole Toffy is working and I'm one vote ahead :( haha
Everyone has suggested both of us, so how about we both do it?
since its such a big massive job and too much for one bloke to handle.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5213157
Appears my smear campaign on that asshole Toffy is working and I'm one vote ahead :D haha
haha well i vote for toffy :P
nah i'm not phased , it's all good by me :(
Have either of you moderated a forum before?
ahh no? :D
https://www.sau.com.au/forums/topic/318853-new-moderator/#findComment-5213918
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
