almost to the point of having to select brake pads for my car.
I am running porsche 6 pot front calipers on 365mm rotors and porsche 4 pot calipers on 328mm rotors rear on a 1200 KG Z32
Racing will initially be sprints and car has 350-400 RWKW
I have looked at the ferodo 3000's but dont think I can get them hot enough quick enough for them to work properly.
Pagit yellows ( I like these)
Endless ( no idea which one )
Porterfield ( no idea about these )
Project Mu ( no idea about these either)
I would prefer a softer pad with less rotor wear. Requirements are to get up to temperature FAST and have a high co-efficent of friction because the cars brakes are unboosted.
Can I have peoples thoughts on what pad material in each brand would suit me or your personal experience with what you use?
Thanks
Edited by Tektrader69
G'day mate,
I use the SBS carbon ceramic pads on my GTR - after using them on my car for the last 3 years or so I can report that they are an excellent pad for sprints. From my experience they have great bite even when not fully up to temp and I have never experienced pad fade. The rotor wear speaks for itself - I am using the std brembo brakes and std rotor sizes with DBA5000's up front and have had the same front rotors on the car for about 3 years and only now are the slots getting worn away. This is with around 8-10 track days a year plus a bit of road use.
Thanks
Hi Tektrader,
Which 6 pot and 4 pot Porsche calipers are you running ?
Are you running the 6 piston Motorsport Department Calipers like these ? ...
... or one of the road car calipers ?
We have a lot of knowledge about the Porsche calipers and what works in custom applications etc. There is a page here with info about using Porsche Motorsport Department Calipers in custom applications ... http://www.tunersgroup.com/porsche_brakes.html
In terms of the Project Mu pad compounds and Endless pad compounds, we have very detailed pad compounds overviews for both Project Mu pads and Endless pads on our website, particular racing and competition pads, which may be of interest to you.
Our Project Mu Pad Compounds Overview is here ...
http://www.tunersgroup.com/Products/pmu_pad_specs.html
Our Endless Pad Compounds Overview is here ...
http://www.tunersgroup.com/endless_pad_specs.html
Hope that info is helpful :P
- The Tuners Group
Those are exactly my calipers. I have been doing a fair bit of reading and are strongly leaning toward the Pagid RS14 Black
Now i have had a quick look at your site. What have you in the way of caliper adaptors for a R32 GTR that will suit these calipers? and for what size rotors?
I have managed t get a apir of 365mm Alcon rotors for a very good price and would like to use those.
lastly while I was test fitting pads the other day. There appears to be A LOT of extra width in these calipers when the pads are fitted . Looks almost enough to fit 40mm rotor in there. What is the design rotor thickness of these calipers? 32mm or 35mm ??
Hi Tektrader,
Nice caliper choice - they're a beautifully engineered caliper.
You wrote above ... "I am running porsche 6 pot front calipers on 365mm rotors".
There is a version of the Porsche Motorsport Department 6 piston caliper designed for a 350 mm rotor and another version of the Porsche Motorsport Department 6 piston caliper designed for a 380 mm rotor. Are you running the caliper designed for the 380 mm rotors with a smaller diameter brake rotor ?
Do you have hats and caliper adapters designed and built to fit them to your car ?
Drop me an email to our email address listed here if you want more info about the various pad compounds available for those calipers or a general yarn about running those calipers on a GT-R and what brake rotors will work with them - we have a bunch of info on those calipers and what disk sizes they run ex-factory etc ... http://www.tunersgroup.com/Contact_Us/
- The Tuners Group
Edited by TheTunersGroup
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
