hey guys seam to be having a bit of trouble with my diff, and i am after advice..
what has been happening over the last 6 or so months is the diff seams to be getting very tight/clunky
when turning at a T intersection when i have just taken my foot of the clutch.
now it is starting to do this at higher speeds which it never used to do (40kph thru a roundabout)
can anyone tell me what is actually happening as it is just the stock diff, and it never used to do it.
if i need to look at replacing things, what should i be looking for, jut shimming, rebuilding, aftermarket?
i just want it to stop clunking :P
also my friend mentioned to me that i should stop driving it incase it locks up, will it actually lock up, and if it does
what will happen? in anycase i think it will need to see a mechanic, as its my daily driver.
any advice would go a long way, thanks.
https://www.sau.com.au/forums/topic/319021-what-will-happen-when-it-locks/
And to answer the questions about the locking
I got a nismo 2 way diff which is always locked. Let's say you are on a bend accelerating gently and you back off the accelerator I feel the back end kick out. Worst thing in your case is that you don't know when it's going to lock. Pretty much just have to worry about understeer and the back end coming out when it locks
if it locks it wont just kick out he will need a lot of speed it will just be even clunkier..
agree with you though doesnt sound like a stock diff cos they just single spin most of the time haha.. get it looked at man best thing to do
Sounds like you may have a decent aftermarket diff and is LONG overdue for an oil change.
I know with my Kaaz diff, i need to change the oil every 10,000-15,000km. As the oil gets older, the diff gets clunkier and noisier.
I have driven a 33 with a welded diff, it's not that bad/dangerous; you just need to keep it in mind on wet roads and take it a little easier.
You guys might be on to something with the aftermarket diff. The car did have after market greddy suspension, i have it booked into the mech next monday to have the drivers side ball joint replaced, hopefully the diff just needs some new oil. Will the mechanic have to take the housing of to have a look, and will there be any special markings or stamps on afyermarket diffs? (so the stock diff would never "clunk" in a tight corner right?)
since we on the topic of diffs.
Anyone got advice with driving with a 2 way diff on the street? thinking of getting one in the future and i like to do alot of research before hand!
and i'm trying to get into drift hence the 2 way
nothose pictures dont help you need to pull the rear housing of the diff to check what sort of centre you have and it def sounds like a 1.5way 2ways are usually really noisy make sure your mechanic dosnt try to rip you and replace the whole assembly as for driving with a 2 way take extra care in the wet when down changing gears sometimes its like pulling the handbrake on if your doing a lot of street driving maybe stick with a 1.5 way
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
