guys..just wanna make it as simple explanation of my situation...
in 1st gear...
1. rev the engine with no boost ----> car jerks, lost power when reach 4.5/5k rpm
2. rev the engine with boost and half throttle (boost steady at 0.7 bar)-----> same as above with missfire
3. rev the engine with boost and full throttle (boost steady at 0.7 bar)-----> same as above plus got black smoked
when cruising in 4th gear....wanna overtake cars
1. floor the throttle and car jerks and no power at all as above symptom (boost reading steady show full boost) and rpm hard to climb to 5k....can't even overtake the cars....
2. gently floor the throttle back and maintain the boost at 0.1 bar and the engine can built up power, rpm can reach 5k and overtake the car...
so what actually happen....? please guide me.... :D
sounds like one of the 3 following issues, or a combination of more than one:
1: spark plugs are worn, gap is too big and creating a miss. solution: new plugs or regap the old ones
2: coil packs are shot (most likely). solution: new coils
3: ignitor pack is shot (least likely). solution: new ignitor pack.
there is also a possibility it is the AFM as well. when they play up the car goes into limp mode and won't rev past about 4500rpm, but it also won't rev past that if you simply rev the car with the clutch in (depending on whether the problem is intermittent or constant).
thanks mate....a post/suggestion/comment here really give me a light at the end of a tunnel... :)
well i will change the coilpacks as suggested.....just bought one set as spare couple of weeks ago...just cross my finger and hope it will settle down my probs....
my RB20 wont rev past 2300RPM when the afm is unplugged so i would be leaning away from AFM if you are getting to 4500. most likely coil packs or sparkplugs. it might be an idea to buy new plugs anyway if you havnt changed them for a while as the electrodes tend to wear out on one side and in effect increase your gap so increasing the chance of missfire. plugs are cheap as chips so replace them and your new coil packs at the same time and listen to her purr! haha
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
