NO TIME WASTERS
Here are the details..
ENGINE:
Internally Standard FJ20ET
Unifilter Ram Pod
High-flowed T3 Turbo
Front-mount Intercooler
GFB Blow-Off Valve
600cc Injectors
Link Plus ECU
Custom Dump Pipe
3" Mandrel Bend Exhaust
Oil Cooler
Fuel Surge Tank
2x Bosch Fuel Pumps
New Timing Chains
DRIVETRAIN:
RB20DET Gearbox
5-button Clutch
R200 LSD with NISMO plates
SUSPENSION:
Tokico Shock Absorbers
King Springs
Whiteline Swaybars
Nolathane Bushes
K-mac adjustable Strut Tops
NISMO Strut Brace
BRAKES:
Slotted DBA Disc Rotors
Pagid Brake Pads
WHEELS:
16x7 Aftermarket Alloys (set)
S13 Alloys (set)
INTERIOR:
2x Fixed Back Race Seats
Autometer Boost Gauge
Sports Pedals
Rear Interior Stripped
STANDARD:
Air Conditioning
Power Windows
Power Steering
PERFORMANCE:
190kW @ the rear wheels in 4th gear @ 14psi boost. (Dyno graph available.)
HISTORY OF THIS CAR:
Came into Australia (Brisbane) in 2002 with the strut brace and shock
absorbers as the only modifications. After a full service, and new timing
chains were fitted, the car was complied and registered in QLD.
After I purchased the car, later in 2002, I performed the above
modifications using reputable and experienced workshops to carry out the
work. (Receipts available.) The car then received an engineers certificate
and was registered in NSW. Registration expires in June, 2004.
The car is in excellent general condition for its age and has been well
maintained.
PRICE:
$7,000 no offers
Genuine buyers only please.
If more details are required please phone: 0425-226-075.
https://www.sau.com.au/forums/topic/31925-fs-dr30-skyline-sydney/
pics sent..
for all others wanting pics...
it would be easier to show you an almost identical pic I found on the net..
see here..
http://members.jcom.home.ne.jp/dr30skyline/my.htm
the only difference between that and the one here for sale is that, the one for sale has a 600 x 300 front mount..
everything else looks identical.
Curious as I am looking for a daily driver (my GT-R is just too good/much for a daily driver in my opinion).
I am in Sydney and have $10k to play with but just need to know about your blow off valve and ram air filter. Aren't these illegal in Sydney? Or does your engineers cert cover these if I was to be pulled over by a copper?
JUSTINFOX...
The car has an aftermarket LINK computer which eliminates the need for an air flow meter, therefore an external venting bov does not affect the air:fuel mixtures and that is why the bov was passed in the engineers certificate.
The Ram pod air filter is also on the certificate but I can't remember WHY it was allowed.
it is all listed in the certificate though so you won't have any issues.
If you are serious, I suggest you call and take a look at it cause it has gone in the trading post and has had a fair bit of interest.
The car belongs to a friend of mine.
his contact number is 0425 226 075.
Take care.
  • 4 weeks later...
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
