  • 2 months later...
so paul has dissected my motor a while ago now, check the attached photos
worrying stuff!
The original builder did not clean the crank, hence one of the oil galleries got clogged up!
which explains the bearing issue!
Luckily everything else was able to be salvaged!
The water pump also started leaking as wasn't sealed correctly and im not even going to get started on the "extended sump"! in Pauls words "its the worst sump ive ever seen"
Original builder should stay away.. far away from ever attempting to build another 26 :spank:
SHIIIITTTT!
thats just disgusting how a business can take your money and do poor work!
atleast the cars in good hands now!
yeh mate.. Pauls showing it some much needed love :3some:
if all goes well, should have it back end of next week or week after
Just read the whole thread, looks like I missed alot of it...
If I was a betting man, i'd say that *********built your motor? I say that based on my own personal experience with an SR I had built by them many years ago...if im right, it would seem he still has no clue about putting Jap motors together...glad youre getting looked after, from all accounts your motor is in good hands, good luck with it mate.
Edited by SLED
You're sailing pretty close to the wind here champ.
I suggest you go and familiarize yourself with the forum rules before even 1 more post.
  • Nope 1
If I was a betting man, i'd say that ******built your motor? I say that based on my own personal experience with an SR I had built by them many years ago...if im right, it would seem he still has no clue about putting Jap motors together...glad youre getting looked after, from all accounts your motor is in good hands, good luck with it mate.
You guess... WRONG :P
ive put a few engines togther over the years but when it comes to high revving long crankshaft engines its best left to the guys who really know them inside out.
Red R build more RB's than anyone in this country and thats all they do. It was a simple choice to make when i decided to throw some big bucks at my current engine.
What a story, just read the whole thing.
Just goes to show that there is no substitute for experience. Good to see how generous people can be in times of need.
Hope you get it all going again soon, it's a very tidy rig.
all the best mnate.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
