Its people like swiper that keep it all alive and make feel its worthwhile owning an import. I take my hat off to the man. Now i dont feel so bad that a split coolant hose is costing me $800 in labour to replace!!
awesome thread!!
some awesome people on hear that are happy to "get a brother off the bench" and help out a fellow japanese car enthusiast/owner!!!!
good luck in the future! bet ya cant wait to drive HER again mate!! :thumbsup:
frack. For $500, id come past and give it a whirl lol.
Done it before, now i usually replace all the hoses when i pull motors. Saves these bs jobs.
yeah. i had all mine replaced with silicon hoses last month when the head was off the car... been in the position where the 3 hardest to get to hoses have split and required loads of labour to repair... preventative maintenance goes a long way
-D
  • 3 weeks later...
cant believe its almost been 12months since my first post!
Big thanks to everyone here with your support and especially PAUL who has been an absolute legend throught this whole process! :cheers:
Car got towed yesterday and engine is being installed over the weekend, starting her up on tuesday!
SOOO glad I decided not to sell, I know i'd be regretting it!
Will provide another update next week
  • 3 weeks later...
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
