1992 nissan 180sx for sale. I need a car asap so looking for quick sale. Car has sunroof, Power everything, no a/c but all a/c parts will be provided. The car also have skyline r33 s2 seats as well so very comfortable, colour is gun metal grey. Car also has receipt of things done to it in the last 6 months or so. Has rego till 14th oct 2010. Car just had all spark plugs changed and also has two rust holes on the boot hatch. Overall, the car is straight with no accident history. However it will a bit of fine tunning and a few bit and pieces done in order for it to run at its best. Also, the temp/speedo doesn't work but I don't have have time to fix it. It will also need a smaller battery to fit in the engine bay nicely. Too much money spent on this car but due to uni, work and debts, i am unable to keep it.
Item Condition: USED
Reason for Selling: I'm over turbo car now so looking for something non turbo.
Price : $7000 ONO
Contact Details: 0422106112
Extra Info:
S14 S2 SR20DET Motor (Approx 68000km with SABER FMIC).
S14 brakes and wheels (5 Studs Conversion Already)
Greddy Profec B Boost controller.
3 inch exhaust.
Imobiliser
Turbo Timer
Apexi Intake
I AM IN NEED OF ANOTHER CAR ASAP. Preferrably a japanese car manual and decent looking preferably a Honda with Vtec. Nothing too special just a reliable daily. If you have another you wanna swap with cash my way, please me know and we'll work something out. Cheers
Photos:
http://img23.imageshack.us/gal.php?g=img0057ut.jpg
Edited by lil_sprinter
https://www.sau.com.au/forums/topic/319906-180sx-for-saleswap/
  • 5 weeks later...
how about an r33 gts (NA manual)?
http://www.skylinesaustralia.com/forums/R3...&hl=r33+gts
PM me if interseted
Edited by 2FST4U.R33
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
