have cam cover and brand new timing belt
belt was fitted to motor and manually turned over
then i stripped the motor so it doesnt come with packaging
$80pp for both ono
yeah bud sounds alright, wud u go any lower ?
where are u located
Hi,
Not too sure if you would be interested but I have a R33 GTS cylinder head.
I am going to have it crack tested, get all the valve train cleaned properly and have it resurfaced.
I would be asking $500 for it with that work done.
Hi,
hey mate, could be interested, how much would you one without the work done ?
where are you located ?
$350
I am on the Gold Coast.
I think it would be best to have the work done so you'll be getting a head thats in perfect condition with no cracks or warps. It is in pieces too and will need to be put back together.
$350
yeah okay if u can get the head properly together and have some sort of garuntee from the head place that its fine.. whats the lowest you will go, on bit of a budget..
hey guys im chasins a good condition RB25DET head
also afterr top & bottom timing cover, harmonic balancer and a good cond timing belt.
Cheap manifolds? ?
thankks
i have a complete rb25 det head and all the reast od the stuff u need but im in nsw call me 0415054272
haha was just checkin bud chill.
look when you get it all done, get back to me okay. will you be doing it soon ?
if you're interested its up for sale. i cbf getting the work done to it, i'll only be throwing away money.
rb25 head for sale
Cheap manifolds? ?
thankks
got a good timing belt top timing cover harmonic balancer and a good head with no broken exhaust studs never overheated straight as clean and golden uptop come off a good running engine i wanted a good crank and rods for my rb23 build so will throw in startup/running warranty this head in very good condition dialled into the right settings so bolt on your manifolds bolt to your block and go all that for 400 cash also have intake manifold txt call or pm 0450 728 189 be quick i'm sure someone will be down for this deal
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
