actually it's type M, not m-spec. m-spec is a model of the r34 gtr.
type m in the r33's basically means that it is a GTS-t. all the GTS-t's were type m except for a handful of the auto sedans which i think were type g or type x (can't remember which) and i think that was mostly due to them having a different gearbox.
the 40th anniversary bit though will give you a few extra cosmetic goodies, but nothing really to get excited over (i think mostly just the bages). i could be wrong but i think that all of the last of the 33's were 40th anniversary models (at least in the gts-t's), and weren't that much different to the rest of the S2 33's. there weren't that many changes even between the s1 and s2 when you get right down to the mechanical stuff that actually make a difference.
The 98 40th Anniversary's just had a couple of extra optional body kits i believe. GTR wing being one part, and a different front bumper. GTR styled.
Mine never had the badges, but has the stitching on the seats. Has the GTR style bumper, and GTR wing.
I got the full shebang on mine cosmetics wise. All i "missed" out on was the sunroof and A-LSD.. not that im worried :thumbsup:
(These werent 40th options btw.. just options)
Edited by gotRICE?
The 40th anniversary Type-M was available as pictured above with a GT-R esque aero kit in a package called the Type-MR. It's very nice in the flesh. It's also badged 40th anniversary on the C-pillar and seats and is available in a special midnight purple colour as well.
I have a dealership brochure for the Type-MR lying around somewhere at home.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
