  • Replies 54
  • 4 weeks later...
hey mate i'm keen on the passenger side headlights..can u post to melbourne? can we negotiate the price? lemme know.. send me a txt or gimme a call...anytime after 3:30pm 0411795674 cheers
hey mate still have the hi flow cat? can u post to melbourne?
Had a closer look at the cat, its not in great condition, I wouldnt want to sell it. Sorry.
Headlight was sold
Hey mate what sort of condition is the P/S pump in?
what year skyline did it come off of?
Cheers, Chris
Not sure on the year sorry, but was working no problems.
Heyy mate, r33 series 1 front bar still available, If so can u ring or txt on 0434080676. Cheers gavin
Sorry sold
hi there,
I'm keen on the factory r33 strut set, i'm in Addy n need for Regency
pm me ur no. if u still have struts available
Cheers
Sorry sold
Hi Jin,
You still have the TEIN coilovers? If so can u please PM me i haven't done enough yet so can't PM u .
Thanks
Yeh I sure do, Ill PM you details
hey mate, you still got the boot? and can you pm me ur address so i can google map it
sorry should specify the red boot
Ill PM you details, I still have the red boot.
hey man i am trying to find how much you would sell the clutch pedal and clutch master cylinder you have for the r33 plus shipping to the usa...
also i was wondering if you would take the lock with the nissan logo off of the boot you have and sell that seperately!
please let me know man thanks!!! i dont have the option to pm yhet or i would i just recently purchased this skyline im part of the skylineownersusa website but it seams to be easier to find parts from this site!! thanks buddy let me know!
Clutch Pedal + Clutch master cylinder can do for $120 AUS, + postage of $55 AUS. So total $175 AUS delivered.
Sorry dont really want to remove the Nissan logo off the boot because Ive got no idea how to remove it.
Interested in the R33 S1 Radiator (the one WITHOUT damage!) Please PM if still available. Thanks.
Ill check and send you a PM, fairly sure Its still in the shed.
Hey mate,
Still got the mats? Interested if you still do
Sorry mate, they look to be sold.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
