Hey how are ya's. My name is Luke and i own a VL Aero. I have installed an Rb25de with 5 speed box. After reading up on the n/a section. i Have decided to do the folowing:
Coby Extractors
CAI
new exhaust 2 1/2
Cam gears (HKS)
larger injectors
bosch 044 fuel pump
Shave the head
port and polish
Now im am unsure as to what type of cams to get.? And Also i have noticed that in some threads that you can get a Blitz N/a computer. Where can i purchase such an item?
Any help would be appreciated! :cheers:
https://www.sau.com.au/forums/topic/32020-hi-guys-im-new/
welcome :O there is a guy on here, username Nick Thompson who has done a lot of mods to his RB25DE including cams i believe...he hasn't posted for ages but it might be worth sending him a pm (private message) to see what hes running (post back here with what you find please :rofl:). he's dynoed it... 137.5kw @ wheels!
oh yeah coby extractors...see www.partsco.com and tell them you're from skylines australia. yes i know you have to pay freight from nz to oz but it still works out cheaper than buying them locally. advan imports in sydney sell them for about $430 from memory, should be able to pick them up from partsco for about $350 shipped to your door.
add safc to your list :O
https://www.sau.com.au/forums/topic/32020-hi-guys-im-new/#findComment-646012
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
