-For sale is brand new in box 86.5mm CP piston set for RB26. Compression ratio is standard 8.5:1
Comes with all rings, gudgeon pins, clips and exact setup measurements.
Looking for $1100 ono. Look around you will not buy these in Australia for this price.
RB26 CP pistons
-Full complete RB26 head without rocker covers reshimmed recently
Looking for $1300 ono
-RB26 R32/33 GTR power FC PRO with hand controller. Yes the one with launch control and ignition rev limiter
$1500 (i really don't want to part with it but it is not being used)
R33 GTR fuel pump 60,000km
$150
R32 GTR front diff and sump complete
$300
RB25/26 head external oil drain kit
$120
RB series head drain
Contact Ben on 0401 779 905 for any other questions
Edited by BK
https://www.sau.com.au/forums/topic/320231-rb26-head-r32-gtr-sump-power-fc-pro/
  • 3 weeks later...
Price drop
$1000 for cp pistons
$1100 for head
$120 R33 GTR fuel pump
$250 GTR sump
Power FC pro + Hand controller - make an offer
Sorry about that. Drain kit is sold pending payment. Rest is still available at:
$1100 for head
$250 GTR sump
Power FC pro + Hand controller - make an offer !
Have to offer more than that for me to let go of the Power FC Pro. They are not very common. Also everyone asking if the Pro unit is d jetro/MAP sensor based the answer is no. You need to run Airflow meters. Following still for sale :
$1000 86.5mm cp pistons + rings - FIRM PRICE
$1200 OS giken R3C triple plate
$250 GTR sump
$1300 Power FC pro + Hand controller
Edited by BK
  • 3 weeks later...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
