sorry if this is in the wrong bit or if im not alowd to do it but i thought that its a good oppertunity for every 1 to save some $$$$$ at some1 elces expence!*** american $ ***
another "crapy" forum is having a 25% o
ff tein coilovers and springs
http://www.tein.com/nissan.html <---- go here get a price
take20-25% off
then here to order them! |
V
http://www.automotiveforums.com/vbulletin/t173913.html
mark
https://www.sau.com.au/forums/topic/32025-cheep-coilovers/
yea i sent them an e-mail bout that, Listed below is the coilover kits that we
offer for the Nissan Skyline R32. If you have anymore questions please feel
free to contact us. Thank you for your interest in Tein High Performance
Suspension,.
HA
TEIN has developed advanced technology to design the shell case and stroke
to bring out the full potential of your vehicle. These features of the TEIN
HA Damper kit were designed with greater performance to satisfy
all your driving demands. This high performance damper can be used for
weekend racing and/or daily driving. The discomfort caused by uneven roads
or bumps are eliminated on daily street use. For race use, the ride height
adjustable system enables you to adjust ride height and 16 levels of damping
force. In other words, you can adjust your vehicle to meet all situations!
- High performance and cost effective
- 16 levels of damping force adjustment (compression and rebound together).
- Ride height adjustable
- New paint coating for rust prevention.
- Pillow ball mounts are optional (on certain applications).
- Available for overhaul in North America.
- MSRP $1400.00
FLEX
TEIN has used its years of experience in various motor sports to produce a
kit that provides the ultimate balance between comfort and performance. The
FLEX Damper Kit features the latest technology for all drivers who are
seeking comfort, performance, and adjustability. We have incorporated
separate spring perch height and shell case length adjustment, which allows
the suspension to retain more stroke and allows for more suspension tuning.
The FLEX Damper kit includes pillow ball upper mounts, which increase
steering response, and is compatible with the EDFC (Electronic Damping Force
Controller), for added convenience and adjustability.
- Full-length adjustment and height adjustment for separate setting of the
height and spring preload.
- Teflon coating for rust prevention.
- Newly designed spring seat and spring seat lock for easy height
adjusting.
- Pillow ball upper mounts are included.
- Compatible with EDFC.
- MSRP $1480.00
CS
TEIN Type CS damper was designed to give comfort to sophisticated drivers.
We adapted a hard rubber upper mount for noise proofing and increased
steering response. A mono-tube type shell case was utilized to increase
valve size and oil capacity for improved comfort and handling. CS was made
for those who want aggressive looks, and increased handling with out
sacrificing any loss in comfort or added noise.
- Improved ride comfort over original shock absorbers.
- Hard rubber upper mount is used for noise proofing.
- Ride Height Adjustable
- A mono-tube design and increased shell case diameter to allow for 30%
more oil capacity, as compared to OEM shock absorbers to handle the upsizing
of wheels with lower profile tires.
- Available for overhaul.
- MSRP $1660.00
RA
TEIN RA has been designed for circuit racing and aggressive street use for
experienced drivers. It incorporates mono-tube design for larger valves and
increased oil capacity. Maximum road handling and driving stability is
achieved through aggressive spring rates and damping force.
- Mon-tube design for maximum performance.
- Constructed of A7050 aluminum for weight savings (on certain
applications), strut type suspensions have an inverted steel shock absorber
for durability.
- levels of damping force adjustment (compression and rebound together).
- Ride height adjustable.
- Exclusive designed pillow ball upper mount for optimum performance.
- MSRP $1770.00
RE
The Tein Type RE is like the Type RA, but with an added full-length
adjustment system. The ride height is adjustable without changing the
preload of the spring. This is the special feature of the full-length
adjustment system due to threads on the lower bracket. The Type RE has a
wide range for setting the stroke and length of the shock. It is possible
to set up this suspension for various road, weather, or track conditions
while maintaining optimal suspension stroke. Features include: mono-tube
design for larger valving and increased oil capacity, aluminum casing for
weight reduction, Full-length adjustment and height adjustment for separate
setting of the height and spring preload, 16 levels of damping force
adjustment, pillowball upper mount, and available for service.
for durability.
- MSRP $1900.00
RS
TEIN has used its years of motor sports experience to develop a kit for
ultimate damper tuning. Type RS damper gives the user separate compression
and rebound adjustment (16 levels x 16 levels), which allows the driver to
set up the suspension damping force to meet any track conditions.
Furthermore, wishbone suspension and multilink suspensions have a reserve
oil tank for larger oil capacity, to reduce added heat from track racing and
performance driving. Strut type dampers are designed with inverted shocks
for more horizontal stability.
- Mono-tube design for maximum performance.
- Compression and rebound damping force is adjustable separately (16 levels
x 16 levels).
- Extra reserve oil tank for larger oil capacity for wishbone and multilink
suspension.
- Inverted structure for more horizontal stability for strut type
suspension.
- Exclusively designed pillow ball upper mounts to optimize performance
- MSRP $2310.00
Best regards,
Sales
Staff @ TEIN USA INC.
9798 Firestone Blvd.
Downey, CA 90241
Phone: (562)861-9161
Fax: (562)861-9171
www.tein.com
https://www.sau.com.au/forums/topic/32025-cheep-coilovers/#findComment-643515
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
